September 12, 2023 at 3:52 am
veerpal kaur
SubscriberHi , I am simulating the RING MODULATORÂ in AMF Technology from one of the example "AMF_1_RingMod.gds". (link for file:Â
https://drive.google.com/file/d/1KMvLglfiNC1Hr3k8Ui_NBLSx6pCRJvkl/view?usp=sharing Â
Here , I am sharing design and error in interconnect window. Kindly help me to solve this issue. I have installed all the library in interconnect.
September 12, 2023 at 9:00 pm
Dev
Ansys EmployeeÂ
Hello, Are you following all the steps here: KLayout Interoperability User Manual – Ansys Optics
Regards
Devika
September 18, 2023 at 4:06 am
veerpal kaur
SubscriberHello Devika,Â
 I followed all the steps as mentioned in the above link. Still, I am facing same problem again. Kindly help me to simulate the design in Interconnect.
Thank you.
September 18, 2023 at 4:32 am
Dev
Ansys EmployeeHello,Â
Can you check Is the ONA "analysis type" property set to "scattering data" or "impulse response"? It should be set to "impulse response for this analysis.
September 18, 2023 at 3:49 pm
September 28, 2023 at 1:40 am
veerpal kaur
SubscriberHello,
anyupdate about the solution of above problem?It has been a while.Â
October 4, 2023 at 9:26 pm
Dev
Ansys EmployeeHello, Apologise for the late response.
I would suggest to uninstall all the Layout environment and do it again following the steps.
https://optics.ansys.com/hc/en-us/articles/4411329620755-KLayout-Interoperability-User-Manual.Â
Can you expand the component (root elament) and send a screensot?Â
I like to check is all elements are connected properly.
Thanks and regards
Devika
- The topic ‘problem with interfacing between klayout and interconnect’ is closed to new replies.
