TAGGED: ansys, mechanical, mesh, meshing, pyramid, tetrahedral
August 6, 2024 at 8:34 am
shivaaditya001
Subscriberi have created a tetramesh with pyramid elements on the outer face so that they can be used as a transitions elements.Â
The elements looked fine in hypermesh but when i imported them in the ansys i cannot see the pyramid elements.please look at the below images.
Please help me through this.
Thankyou.
August 6, 2024 at 9:18 am
ErKo
Ansys EmployeeÂ
Hi
See if the elements you have and try to import are supported:
https://ansyshelp.ansys.com/account/secured?returnurl=/Views/Secured/corp/v232/en/wb_sim/ds_cdb_el_types.html(very likely they are not supported)
See here how to see the link above (if it does not work for you):
https://innovationspace.ansys.com/forum/forums/topic/how-to-access-the-ansys-online-help/All the best
Erik
August 6, 2024 at 10:10 am
shivaaditya001
SubscriberHi Erik thanks for the quick reply, still i need to know how to use pyramid elements in ansys, its confusing. the link is asking the customer number which i dont have.
is there setting/ adjustments that is possible with imported pyramid mesh.Â
or What should i use instead of pyramid elements.
Thankyou.
4838
1587
1386
1242
