Problem with displacement-time data extraction for a transient structural analys
April 6, 2024 at 6:08 pm
shivamr20
SubscriberGreetings, this is shivam. I am a graduate student and I am stuck in a problem with ANSYS MAPDL for quite some time now.I was performing a transient analysis wherein I defined 2 load steps. The time at the end of the first load step was 2 seconds and the time at the end of the second load step was 2.0001 seconds. This was specified using the "time" command. The problem is that I want displacement data as a list for all the substeps defined. From 0 to 2 seconds I can get that data but from 2 to 2.0001 seconds there is a problem. The displacement vs time list at the node of concern gives the time values as 2.000, 2.000, 2.000 as so on and at the end it is 2.0001. I want to tell that for the second load step I defined 700 substeps which means my time values in the list should go on like 2.000000142, 2.000000285 and so on. So that I will be able to plot it on excel.Please help me, I am stuck with this for quite some time now. It will be much appreciated. -
April 8, 2024 at 4:19 pm
dlooman
Ansys EmployeeIf this output is created with the prvar command in post26 then the /format command can help. For example, /format,,F,20,16 produces time values like below for your case.
TIME 2 UX
UX
0.2000000000000000-0.122839E-008
0.4000000000000000-0.245678E-008
0.6000000000000001-0.368518E-008
0.8000000000000000-0.491357E-008
1.0000000000000000-0.614196E-008
1.2000000000000000-0.737035E-008
1.3999999999999999-0.859874E-008
1.5999999999999999-0.982713E-008
1.7999999999999998-0.110555E-007
1.9999999999999998-0.122839E-007
2.0000001428571426-0.122839E-007
2.0000002857142856-0.122839E-007
2.0000004285714286-0.122839E-007
2.0000005714285716-0.122839E-007
2.0000007142857146-0.122839E-007 -
April 9, 2024 at 7:24 am
shivamr20
SubscriberYes, I did that and now the problem is solved. Thanks for the help!
- The topic ‘Problem with displacement-time data extraction for a transient structural analys’ is closed to new replies.
4969
1645
1386
1242
