3D Design
3D Design
Problem with Discovery Initialization
    • WojtekD
      Dear Discovery Team,
      One of our customer has a problem with running Discovery 2020R2.
      Operating system: Windows 10 (fresh instalation) + instaled all newest drivers
      When he try to start Discovery (Discovery AIM) nothing happend or had error like below
      I checked log files and obtained following infformation
       SpaceClaim.Facade.SpaceClaimView.Start(IUnityContainer container, StartOptions options, IEnumerable`1 featureFlags, StartDelegate startDelegate)
          Cause:
              Title: SerializationException
              Severity: Error
              Message: Wystąpił błąd podczas deserializacji obiektu typu Microsoft.Identity.Client.Internal.OAuth2.TokenResponse. Napotkano nieoczekiwany znak „U”.
      Translation in English: An error occurred while deserializing an object of type Microsoft.Identity.Client.Internal.OAuth2.TokenResponse. An unexpected "U" character was encountered.
              StackTrace:    w Ansys.AnsLicensingMgmt.AnsLicensingMgmt.d__29.MoveNext()
              Cause:
                  Title: XmlException
                  Severity: Error
                  Message: Napotkano nieoczekiwany znak „U”.
      Translation in English: An unexpected "U" character was encountered.
                  StackTrace:    w System.Xml.XmlExceptionHelper.ThrowXmlException(XmlDictionaryReader reader, XmlException exception)
      and
      w System.Windows.Threading.ExceptionWrapper.TryCatchWhen(Object source, Delegate callback, Object args, Int32 numArgs, Delegate catchHandler)n
      2023-04-12 13:03:03,265 [MainGuiThread] ERROR - Header: An exception was caught by the global exception handler.
      Title: InvalidOperationException
      Severity: Error
      Message: Właściwości Owner nie można ustawić dla obiektu typu Window, który nie został wcześniej wyświetlony.
      Translation in English: The Owner property cannot be set for an object of type Window that has not been displayed before.
      Have you already encountered such a problem and can give me tips on how to solve such a problem
      Best Regards,
      Wojciech Danek
    • Devendra Badgujar
      Hello WojtekD
      We will have to check license details of the customer to understand this better, please can you share the customer email address and customer number to ansys-discovery-support@ansys.com?
      Regards.
    • Devendra Badgujar
      Hello WojtekD
      I can see that their Ansys Discovery Ultimate license is not active on any device yet, please try activating the license via command lines options shown below:
      Discovery Subscription license - Command line options - Knowledge Base - Ansys Discovery Forum
      Also, there tecs has expired on: 2021-03-23, so they should only be able to use versions released before this date.
      Let me know if further assistance is needed.
      Thank you.
    • WojtekD
      Hello Devendra Badgujar
      Customer activated license on this device, screen sended to You via email was old and its purpose was only to show You customer creditentials.
      Also version of the software (2020R2) is older that date of TECS expiration date
      Customer used this software on different computer and everything worked fine problem occured after fresh Windows instalation
      Best regards,
      Wojciech
      • Devendra Badgujar
        WojtekD
        Please can you ask them to try launching Discovery using Admin rights and see if that helps?
        If the problem persists, type %temp% in Windows Search and locate .ansys folder. Zip this folder and send it to Discovery Support Team
        Also, send following log files located at ~/Ansys Inc
        Install.log
        Install_licconfig.log
        Install.err (if it exists)
        Thanks.
  • The topic ‘Problem with Discovery Initialization’ is closed to new replies.
