March 12, 2024 at 11:32 am
March 13, 2024 at 7:55 am
Sampat Kumar
Ansys EmployeeHi Mateusz Kozar,
Will you please try to flip the contact and target sides and let me know if the visibility issue still exists?
I don't think it's a problem with the transparency of the body. Which side of the body do you want more transparent? Will you please explain the question in detail?
Best Regards,
Sampat -
March 13, 2024 at 9:59 am
April 12, 2024 at 4:21 pm
Sampat Kumar
Ansys EmployeeHiÂ
Thanks for your patience.Â
I am not sure if you are working on this issue or not but I am providing a solution that would help others with similar issues.Â
As I can see in your first image, you have selected multiple sides on the two different bodies that's why there might be a chance that you are not able to see the transparent body.Â
It's similar to that I have attached in the image below. Please select the contact side properly and let me know if you face any issues.Â
Best Regards,
Sampat
- The topic ‘Problem with contact/target view.’ is closed to new replies.
4633
1535
1386
1225
