February 3, 2026 at 11:15 am
malte.koehn
SubscriberHi everyone,
I’m relatively new to LS-DYNA and I’m facing a problem with the *CHANGE_CURVE_DEFINITION command.
In my initial input deck, I define a curve as follows:
*DEFINE_CURVE
$    ID    sidr    sfa    sfo    offa    offo   dattyp  unused1
     1     0    0.0    0.0    0.0    0.0     0     0
$# Â Â Â Â Â Â Â Â a1 Â Â Â Â Â Â Â Â Â o1
         0.0         0.0
$ Â Â Â Â Â Â Â Â a1 Â Â Â Â Â Â Â Â Â o1 Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â Â unused1
         2.0         0.05Now I want to change this curve after a restart, but the *CHANGE_CURVE_DEFINITION command does not work as I expected.
I used it as follows:
$ Â Â Â ID
     1
         2.0         0.5
         4.0         0.5Â
When I run the restart, I get the following error:
 *** Error 10246 (KEY+246)
   line contains improperly formatted data
   reading *CHANGE_CURVE card.
     At line# 9 of file
 d:\lsdyna\restart\inputbalken_r.k
         2.0         0.5
 *** Warning 10453 (KEY+453)
   blank line where command expected
     At line# 11 of file
 *** Error 10133 (KEY+133)
   input data failed with: 2 errors E r r o r  t e r m i n a t i o nÂ
How do I use the *CHANGE_CURVE_DEFINITION command properly, or what am I doing wrong?
Thanks in advance!
February 5, 2026 at 12:21 pm
ErKo
Ansys EmployeeÂ
Hi
It is a tricky one not very well documented I would say.
The error is because it is not used that way – this keyword takes only LCID which is the curve to change.
In summary, if you want to change load cuve ID 5 say from the original model, you can set LCID=5 in the *CHANGE_CURVE_DEFINITION (see how this should look like below) and add the new *DEFINE_CURVE with ID=5 and the new values in the restart input file. But, the new load curve with ID=5 in the restart must have the same number of points as the curve LCID=5 in the original model (see help manual).
I find it easier to define a new curve (say ID=448) in the restart and use it there.
All the best
PS:
$ Â Â Â ID
$# Â Â lcid
     5
*DEFINE_CURVE
$#   lcid    sidr    sfa    sfo    offa    offo   dattyp   lcint
     5     0    0.0    0.0    0.0    0.0     0     0
         0.0         0.0
         2.0         0.50Â
5289
1885
1403
1268
