TAGGED: 2D, boundary-conditions, error, heat-transfer, structure
June 22, 2021 at 11:12 am
tiagom1995
SubscriberHi,
I am currently trying to do a 2D thermal model. This needs to have a enclosure type: Perfect, however, ANSYS steady-state thermal refuses to run the simulation unless the enclosure type is set to "open". However, this would give me the wrong results.
I have attached an image of the model.
June 23, 2021 at 9:48 am1shan
Ansys EmployeeFor the enclosure to be perfect, the sum of view factor for a surface should be = 1. This means that the heat radiating from a surface must fall on some other surface(no ambient radiation). Is that the case in your problem? Have a look at 1. https://www.youtube.com/watch?v=gWsogRf9VIM and 2. https://www.youtube.com/watch?v=DRru2pBUF5A.
Regards Ishan.
Viewing 1 reply thread- The topic ‘Problem with ANSYS surface to surface enclosure type.’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
Top Contributors-
3862
1414
1220
1118
1015
