Problem with ACP. Please Help!!! Urgent please
    • manmorcan
      Hello everybody,
      I'm having a huge problem with ACP. I can't solve it and I need your help. This is the problem:
      I did this:
    • Govindan Nagappan
      Hi Array nIf you check the legend, the calculated min, max is -0.29323,0.0014295nIt is not e+127nYou have created a custom legend with large values. See if you can set it back to default. ( Right click on legend and select reset all) Or insert a new displacement resultn
