Electronics
Electronics
Problem while sweep around axis
    • Marco Airoldi
      I'm attending the getting started class of Maxwell. The first exercise, when i draw a polygon curve and try to sweep it around the x axis, maxwell outputs an error even though i've input exactly the same values and followed the exact same steps.
      The error is
      PARASOLID ERROR: sweep failed function PK_BODY_make_swept_2type PK_BODY_sweep_tool_self_int_c.
      Body could not be created because of invalid parameters to sweepAroundAxis operation.
      Could you help me out please ?
    • GLUO
      Hi Marco,
      The training document example was using 2022R2 and before versions. There is a geometry kernel update update after 2022R2 version. Could you let me know which version of AEDT you are using?
      GL
  • The topic ‘Problem while sweep around axis’ is closed to new replies.
