Ansys Products
Ansys Products
Problem when opening workbench (Ans.SceneGraphChart.SceneGraphAddin)
    • swiftgtx
      Hello, I am Installing ANSYS student 2019 R3 and have the following error when opening the workbench:
      An unexpected error has occurred: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
      --- System.AggregateException: The following required addins could not be loaded: Ans.SceneGraphChart.SceneGraphAddin. The software will exit.
      --- System.Exception: SceneGraph.Engine - failed to boot up.
         at Ans.SceneGraphChart.Engine..ctor(IConfiguration p_config, IErrorHandler p_errorHandler)
         at Ans.SceneGraphChart.SceneGraphAddin.Load(AddinLoadContext context)
         at Ansys.Core.Addins.AddinManager.setupAddin(String path, String name, AddinBase addin)
         at Ansys.Core.Addins.AddinManager.LoadAddin(String name, String path)
      I have already updated the graphics card driver, and tried everything on these posts but the problem persists:
      /forum/forums/topic/ans-scenegraphchart-scenegraphaddin/
      /forum/forums/topic/fatal-error-showing-that-the-view-graphscene-has-not-been-registered-how-to-fix-it/
      /forum/forums/topic/workbench-18-2-fatal-error-framework-error/
      I have tried changing the pc and user name as well, and reinstalled the program with the firewall disabled and admin privileges but still have the same problem.
      these are the PCs specs:
      when i run dxdiag this is what i get:
      I hope you can help me find a solution, thank you.
    • tsiriaks
      For your AMD card settings, try something similar to this
      https://support.serato.com/hc/en-us/articles/202305784-Changing-graphics-card-settingsDo you have any install.err-to-use-your-dedicated-GPU-on-a-Windows-computer-
      Do you have any install.err file under C:Program FilesANSYS IncANSYS Student folder ?
      Can you post the screenshot of the output of the 'set' command (without quote ' ') in the CMD Prompt ?
    • swiftgtx
      Hello tsiriaks, thank you for your fast response, I followed the instructions on this post:
      but could only modify the parameters for the intel integrated card, the AMD Radeon app i have installed doesn´t allow any of the changes stated in the post.
      there is an install.err file on the ansys student folder:
      here are the cmd prompt screenshots for set command:
      what should i do next? thank you.
    • tsiriaks
      When you tried changing the username, did you change the username and computer name to English letters only ?
      Please post the content of the install.err file in the content of your post. Otherwise, post its screenshots
    • swiftgtx
      I have changed both the username and pc name to all english letters. i will see if i can post the .err file content as i have been experiencing some issues with the forum when trying to do so.
    • swiftgtx
      ANSYS installation: Sun Nov 24 19:157 2019
      Revision: 2019 R3
         ###### Error #######
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluent2dWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluent2ddpWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluent3dWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluent3ddpWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgfluentWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsfluentWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653distcompWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgcfdpostWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653aviewWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsaviewWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsspaceclmWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653electroWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653ecadxltrWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cadsspatialiopWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cadsspatialWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653acpWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addinsacpWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsacpWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configshelpWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653chemkinWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configschemkinWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgforteWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsforteWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fensapWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsfensapWINX64.7z
         During installation media extract, could not find file: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsansconfigdllWINX64.7z
    • swiftgtx
      here are the full err file contents:
      Start Installation: Sun Nov 24 19:02:49 2019
      Revision: 2019 R3
      Platform specifics:
          Windows
      Username of Installer: DESKTOP-8641BNHAgust?n
      User Has Administrator Privileges
      C:UsersAGUSTN~1AppDataLocalTempans_install_tmp4268instcore.exe -usetempdir C:UsersAGUSTN~1AppDataLocalTempans_install_tmp4268 -launchdir C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653 -admin
      Initial mount directory:
      Installation Directory:
      Windows x64
      Date verification complete...No conflicts found.
      The installation will copy the prerequisite setup files from the media in case you need to reconfigure later or if you need to configure client machines for products installed to a network share.
      This may take a while ...
      Successfully copied prerequisites from media.
      You're missing required prerequisites.
      Installing MS VC++ 2017 Redistributable x86
      Everything was successfully installed.
      Reading the installation media contents - please wait.
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653framewrkWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653instcoretclCOMMON.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653instcoretclWINX64.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653commonWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653commoninstallWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configscommonWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cpythextWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cpythnewWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653turbogrdWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configstgWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cfxcomonWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653instutilINSTUTIL.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653instcoretkCOMMON.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653instcoretkWINX64.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsclientlicensingWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configswbWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653sgchartsWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fwgfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addinsWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgwbWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653corewbWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cadscadaisolWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cadscadregistryWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653ekmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgekmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgminervaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653meshingWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653blademodelerWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653apipsrvWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653designmodelerWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653syscplgWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653rsmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgturbosysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653secWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653ccmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cadsacisparaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653ansysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653voxelWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsansysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgansysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653solverWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653aasWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653dataDATA.GZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653apdlAPDL.GZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653geomparaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgmechWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653autodynWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgautodynWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgcfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configscfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653postWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cffWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluentcWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluentsWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluentaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluentuWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluentpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluentmWINX64.7z ...
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluent2dWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluent2ddpWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluent3dWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fluent3ddpWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgfluentWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsfluentWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653distcompWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgcfdpostWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653aviewWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsaviewWINX64.7z
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653spaceclmWINX64.7z ...
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsspaceclmWINX64.7z
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653icemwbWINX64.7z ...
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653electroWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653ecadxltrWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cadsspatialiopWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653cadsspatialWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653acpWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addinsacpWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsacpWINX64.7z
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653hlphlpviewerHLPVIEWER.7z ...
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configshelpWINX64.7z
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653tpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653tphdf5WINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653tpzlibWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653tpjreWINX64.7z ...
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653chemkinWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configschemkinWINX64.7z
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653forteWINX64.7z ...
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653addincfgforteWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsforteWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653fensapWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsfensapWINX64.7z
      Error: File Not Found: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653configsansconfigdllWINX64.7z
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653studentWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653licenseWINX64.7z ...
      RSS is disabled
      Performing licensing configuration via the following command...
         "C:Program FilesANSYS IncANSYS StudentShared Filesbinwinx64tclsh.exe" "C:Program FilesANSYS IncANSYS StudentShared FilesLicensinglicadminscriptsLicAdminMain.itcl"  -silentinstallclient -release "2019 R3" -lang en-us
      Licensing configuration has completed.
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigCommon.exe
      Configuring ANSYS TurboGrid ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigTG.exe
      Creating Start menu items for ANSYS client licensing ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigWB.exe
      Running "C:Program FilesANSYS IncANSYS Studentv195RSMbinAnsConfigRSM.exe" -encodingUTF8
      Configuring RSM...
      Configuring default RSM and ARC Port numbers for 2019 R3 ...
      Done!
      User has Administrator privileges
      Creating Start Menu Shortcut for RSM 2019 R3 Configuration...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Configuration 2019 R3.lnk
      Creating Start Menu Shortcut for RSM 2019 R3 Job Monitor...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Job Monitoring 2019 R3.lnk
      Creating Start Menu Shortcut for RSM 2019 R3 Cluster Monitor...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Cluster Monitoring 2019 R3.lnk
      Creating Start Menu Shortcut for ARC 2019 R3 Configuration...
      Created Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerARC Configuration 2019 R3.lnk
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigANSYS.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigCFX.exe
      Configuring ANSYS Viewer ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigSpaceClaim.exe
      Configuring ACP ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigACP.exe
      Configuring Help ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigHelp.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigCHEMKIN.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigFORTE.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64configAnsConfigFENSAP.exe
      Running "C:Program FilesANSYS IncANSYS Studentv195aisol..commonfilesCADbinwinx64Ans.CadInt.CADConfigurationUtility.exe"
      Log files is C:Program FilesANSYS IncANSYS Studentv195CADConfigLogsLatestCADConfigurationMgr.log
      MessageLogger.logFilePath is C:Program FilesANSYS IncANSYS Studentv195CADConfigLogsLatestCADConfigurationMgr.log
      ErrorLogger.errorFilePath is C:Program FilesANSYS IncANSYS Studentv195CADConfigLogsCADConfigurationMgr.err
      Prerequisites ..... Configure Success
      SCDM  Workbench  PlugIn ..... Not Configured
      Successfully created file associations.
      The installation completed with warnings/errors. Review any .err or .log files in:
      Installation Complete: Sun Nov 24 19:157 2019
      Start Installation: Sun Nov 24 19:451 2019
      Revision: 2019 R3
      Platform specifics:
          Windows
      C:UsersAGUSTN~1AppDataLocalTempans_install_tmp3084instcore.exe -usetempdir C:UsersAGUSTN~1AppDataLocalTempans_install_tmp3084 -launchdir C:UsersAGUSTN~1AppDataLocalTempRar$EXa7852.21666 -admin
      Windows x64
      You don't need to install any prerequisites.
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7852.21666instcoretclCOMMON.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7852.21666instcoretclWINX64.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7852.21666studentWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa7852.21666licenseWINX64.7z ...
      RSS is disabled
      Configuring RSM...
      Done!
      Configuring ACP ...
      Installation Complete: Sun Nov 24 19:47:05 2019
      Start Uninstallation: Sun Nov 24 19:59:15 2019
      Revision: 2019 R3
      Platform specifics:
          Windows
      C:UsersAGUSTN~1AppDataLocalTempans_install_tmp1680instcore.exe -usetempdir C:UsersAGUSTN~1AppDataLocalTempans_install_tmp1680 -launchdir "C:Program FilesANSYS IncANSYS Studentv195" -admin -uninstall
          C:Program FilesANSYS IncANSYS Studentv195installer
        Extraction: C:Program FilesANSYS IncANSYS Studentv195installerinstcoretclCOMMON.TGZ ...
        Extraction: C:Program FilesANSYS IncANSYS Studentv195installerinstcoretclWINX64.TGZ ...
      Processing selections for uninstall ...
        Attempting to terminate running processes whose images will be removed ...
      Successfully unregistered DLLs...
      Running "C:Program FilesANSYS IncANSYS Studentv195aisol..commonfilesCADbinwinx64Ans.CadInt.CADConfigurationUtility.exe" -unconfigure
      Prerequisites ..... Unconfigure Success
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64unconfigAnsUnconfigCommon.exe
      Unconfiguring ANSYS TurboGrid ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64unconfigAnsUnconfigTG.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64unconfigAnsUnconfigWB.exe
      Running "C:Program FilesANSYS IncANSYS Studentv195RSMbinAnsUnconfigRSM.exe" -encodingUTF8
      Unconfiguring RSM...
      Removing Start Menu Shortcut for RSM Configuration ...
      Deleted Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Configuration 2019 R3.lnk
      Removing Start Menu Shortcut for RSM Job Monitoring ...
      Deleted Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Job Monitoring 2019 R3.lnk
      Removing Start Menu Shortcut for RSM Cluster Monitoring ...
      Deleted Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerRSM Cluster Monitoring 2019 R3.lnk
      Removing Start Menu Shortcut for ARC Configuration ...
      Deleted Shortcut C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve ManagerARC Configuration 2019 R3.lnk
      Deleted Shortcut Folder C:ProgramDataMicrosoftWindowsStart MenuProgramsANSYS 2019 R3Remote Solve Manager
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64unconfigAnsUnconfigANSYS.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64unconfigAnsUnconfigCFX.exe
      Unconfiguring ANSYS Viewer ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64unconfigAnsUnconfigSpaceClaim.exe
      Unconfiguring ACP ...
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64unconfigAnsUnconfigACP.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64unconfigAnsUnconfigHelp.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64unconfigAnsUnconfigCHEMKIN.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64unconfigAnsUnconfigFORTE.exe
      Running C:Program FilesANSYS IncANSYS Studentv195commonfilesconfigswinx64unconfigAnsUnconfigFENSAP.exe
        Beginning file removal ... ...
      Uninstallation Complete: Sun Nov 24 20:01:53 2019
      Start Installation: Sun Nov 24 21:23:17 2019
      Revision: 2019 R3
      Platform specifics:
          Windows
      C:UsersAGUSTN~1AppDataLocalTempans_install_tmp8940instcore.exe -usetempdir C:UsersAGUSTN~1AppDataLocalTempans_install_tmp8940 -launchdir C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749 -admin
      Windows x64
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749framewrkWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749instcoretclCOMMON.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749instcoretclWINX64.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749commonWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749commoninstallWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configscommonWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749cpythextWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749cpythnewWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749turbogrdWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configstgWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749cfxcomonWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749instutilINSTUTIL.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749instcoretkCOMMON.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749instcoretkWINX64.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configsclientlicensingWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configswbWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749sgchartsWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fwgfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addinsWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addincfgwbWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749corewbWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749cadscadaisolWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749cadscadregistryWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749ekmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addincfgekmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addincfgminervaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749meshingWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749blademodelerWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749apipsrvWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749designmodelerWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749syscplgWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749rsmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addincfgturbosysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749secWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749ccmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749cadsacisparaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749ansysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749voxelWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configsansysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addincfgansysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749solverWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749aasWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749dataDATA.GZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749apdlAPDL.GZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749geomparaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addincfgmechWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749autodynWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addincfgautodynWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749cfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addincfgcfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configscfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749postWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749cffWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fluentcWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fluentsWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fluentaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fluentuWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fluentpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fluentmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fluent2dWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fluent2ddpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fluent3dWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fluent3ddpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addincfgfluentWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configsfluentWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749distcompWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addincfgcfdpostWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749aviewWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configsaviewWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749spaceclmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configsspaceclmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749icemwbWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749electroWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749ecadxltrWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749cadsspatialiopWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749cadsspatialWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749acpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addinsacpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configsacpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749hlphlpviewerHLPVIEWER.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configshelpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749tpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749tphdf5WINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749tpzlibWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749tpjreWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749chemkinWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configschemkinWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749forteWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749addincfgforteWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configsforteWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749fensapWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configsfensapWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749configsansconfigdllWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749studentWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa6396.17749licenseWINX64.7z ...
      RSS is disabled
      Running C:Program FilesANSYS IncANSYS Studentv195FrameworkbinWin64Ans.DriverSetup.exe
      Configuring RSM...
      Done!
      Adding write permissions for Users and Administrators group ...
      Configuring ACP ...
      ANSYS Internet Doc has been configured.
      SCDM  Workbench  PlugIn ..... Configure Success
      Installation Complete: Sun Nov 24 21:42:13 2019
      Start Uninstallation: Mon Nov 25 10:44:23 2019
      Revision: 2019 R3
      Platform specifics:
          Windows
      Username of Installer: AGUSTINAgust?n
      C:UsersAGUSTN~1AppDataLocalTempans_install_tmp9136instcore.exe -usetempdir C:UsersAGUSTN~1AppDataLocalTempans_install_tmp9136 -launchdir "C:Program FilesANSYS IncANSYS Studentv195" -admin -uninstall
      SCDM  Workbench PlugIn ..... Unconfigure Success
      Uninstallation Complete: Mon Nov 25 10:470 2019
      Start Installation: Fri Nov 29 11:27:12 2019
      Revision: 2019 R3
      Platform specifics:
          Windows
      C:UsersAGUSTN~1AppDataLocalTempans_install_tmp10916instcore.exe -usetempdir C:UsersAGUSTN~1AppDataLocalTempans_install_tmp10916 -launchdir C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975 -admin
      Windows x64
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975framewrkWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975instcoretclCOMMON.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975instcoretclWINX64.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975commonWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975commoninstallWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configscommonWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975cpythextWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975cpythnewWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975turbogrdWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configstgWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975cfxcomonWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975instutilINSTUTIL.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975instcoretkCOMMON.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975instcoretkWINX64.TGZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configsclientlicensingWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configswbWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975sgchartsWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fwgfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addinsWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addincfgwbWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975corewbWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975cadscadaisolWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975cadscadregistryWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975ekmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addincfgekmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addincfgminervaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975meshingWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975blademodelerWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975apipsrvWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975designmodelerWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975syscplgWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975rsmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addincfgturbosysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975secWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975ccmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975cadsacisparaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975ansysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975voxelWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configsansysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addincfgansysWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975solverWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975aasWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975dataDATA.GZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975apdlAPDL.GZ ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975geomparaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addincfgmechWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975autodynWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addincfgautodynWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975cfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addincfgcfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configscfxWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975postWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975cffWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fluentcWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fluentsWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fluentaWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fluentuWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fluentpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fluentmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fluent2dWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fluent2ddpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fluent3dWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fluent3ddpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addincfgfluentWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configsfluentWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975distcompWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addincfgcfdpostWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975aviewWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configsaviewWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975spaceclmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configsspaceclmWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975icemwbWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975electroWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975ecadxltrWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975cadsspatialiopWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975cadsspatialWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975acpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addinsacpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configsacpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975hlphlpviewerHLPVIEWER.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configshelpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975tpWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975tphdf5WINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975tpzlibWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975tpjreWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975chemkinWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configschemkinWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975forteWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975addincfgforteWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configsforteWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975fensapWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configsfensapWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975configsansconfigdllWINX64.7z ...
        Extraction: C:UsersAGUSTN~1AppDataLocalTempRar$EXa8464.42975studentWINX64.7
    • tsiriaks
      Change your installation package directory. It was set to C:UsersAGUSTN~1AppDataLocalTempRar$EXa7032.23653 , I would recommend to use C:Temp.
      Wipe out the entire C:Program FilesANSYS Inc  folder and try reinstalling it again.
    • swiftgtx
      I followed your instructions and the error persists. What should I do next?
    • tsiriaks
      You still have the same errors in your install.err ? Can you post the updated logs ?
      What is the default 'unzip' tool you have on the machine ?
      Can you try using your test user account (with only English letters in the username) to install the software ?
    • swiftgtx
      the previous unzip tool used was winrar, on this occasion I used 7zip since i no longer have winrar installed.
      I will try using the test user account to reinstall the software and i will let you know what happens. thank you!
      here are the updated error file contents:
      Revision: 2019 R3
      Platform specifics:
          Windows
      Windows x64
      RSS is disabled
      Configuring RSM...
      Done!
      Configuring ACP ...
      Revision: 2019 R3
      Platform specifics:
          Windows
      Windows x64
      RSS is disabled
      Configuring RSM...
      Done!
      Configuring ACP ...
      Revision: 2019 R3
      Platform specifics:
          Windows
      Revision: 2019 R3
      Platform specifics:
          Windows
      Windows x64
      RSS is disabled
      Configuring RSM...
      Done!
      Configuring ACP ...
      Revision: 2019 R3
      Platform specifics:
          Windows
      Revision: 2019 R3
      Platform specifics:
          Windows
      Windows x64
    • swiftgtx
      I reinstalled the software with another user account and it worked fine, but when i go back to my account it still has the same problem. I changed the username to all english letters but for some reason it still shows it with í in Agustín. Do you know how to solve this? otherwise I think i will have to format the pc and start fresh. Either way, Thank you for your help.
    • tsiriaks
      That's great news ! At least we found a way to make it work.
      When you changed your current user account to a new username, can you exclude 'i' just in case ? Also, make sure that your change affects 'everywhere' by checking the output of 'set' command without quote (' ') in the CMD Prompt, you should not see anywhere in this output that mentions your old username.
    • swiftgtx
      I tried changing again the pc and username and excuding the í, but it looks like the change doesn´t work correctly, it still shows the old name on the CMD prompt. iI believe the best course of action is to format the pc and start fresh, so i´ll do that  as soon as possible and reinstall Ansys. Thank you very much for your help.
    • tsiriaks
      I see. Thank you for the input.
Viewing 14 reply threads
  • The topic ‘Problem when opening workbench (Ans.SceneGraphChart.SceneGraphAddin)’ is closed to new replies.
