May 28, 2024 at 5:48 pm
javat33489
SubscriberHi all.I'm doing a calculation of a centrifugal pump wheel.I calculated one wheel, recorded the data on the outlet, and now I want to transfer it to the inlet to simulate the transfer of fluid speed from one wheel to the next.When specifying reading to an inlet from a recorded outlet, a distortion occurs; when I try to shift the outlet to the inlet, instead of a circle of data I get a stripe:Help me please! Why is that? -
May 29, 2024 at 6:38 pm
javat33489
SubscriberColleagues. I did the same thing several times and miraculously the profile moved to the required distance, where the inlet was located.Next, I carry out the initialization and start the calculation, but I get an error:Why???Let's go through the full path again, briefly what I did:1. Created an out profile and specified speed, K and Omega to be written to it.2. Performed calculations until convergence took 500 iterations.3. Next, I create another profile for recording out2 so that the current out profile is not overwritten at the next start.4. I read the out profile file, create a new profile based on it using ORIENT and transfer its coordinates to the place where the inlet is located.5. In Boundary Conditions on the inlet I change the pressure to the speed (at the first start I set the pressure to determine the speed after the first wheel), in the inlet settings I set the reading data from point 4: speed, k and omega. The output also remains the same as at the first start.6. I do the initialization and start the calculation.7. I get an error.Please help me, what did I miss? -
May 31, 2024 at 6:24 pm
javat33489
SubscriberGuys, this error occurs if the recorded file has 0 or letters, but everything is fine there, I have attached a file with the recorded data from the output profile:
June 3, 2024 at 1:58 pm
Forum ModeratorWhy are you using x in all three fields in the alignment tool?
June 4, 2024 at 7:28 pm
June 5, 2024 at 12:50 pm
Forum ModeratorIf you initialise from the inlet what does the flow look like?
June 5, 2024 at 5:16 pm
javat33489
SubscriberSir, I did not understand your question. Can you write in more detail what you mean?
I think that if I transfer the flow from the outlet to the inlet, then the liquid will flow at the same speed as at the outlet, which is what we recorded in the file.
July 2, 2024 at 1:55 pm
Forum ModeratorIf you have translated, transferred and set the data correctly it will. Otherwise it won't, this helps work out what's going on in your model.
Viewing 5 reply threads
- The topic ‘Problem when assigning a surface from a recorded profile’ is closed to new replies.
1307
