Kampus Merdeka Belajar
Ask questions related to general and focused sessions.
Problem w/ Cannot Perform Full Multi Grid (FMG) Initialization
    • Soni Fachryan Akbar
      Does this problem only happen to me?
      Note: I was just about to calculate the case from "Governing Equations of Fluids" course, "Impinging Jet on a Heated Cylinder" simulation. Then this problem happened
    • Raihan Lutfianto
      Hi Soni. Please ensure that you do not run two Fluent application at the same time. Just restart your PC and try again. You may also consider to work on this problem via Workbench instead Fluent standalone
  • The topic ‘Problem w/ Cannot Perform Full Multi Grid (FMG) Initialization’ is closed to new replies.
