TAGGED: #fluent-#ansys, ansys-help, computer, configuration, designpoints, help-me, please-help, update, update-failed, workbench
April 25, 2024 at 3:23 pm
Jorge Isaac Sanchez Ivanov
SubscriberÂÂHello,ÂI am working on a parametric project with Fluent at home with my students license. When I calculate from Workbench updating all design points everything goes fine until I stand up from desk and go to sleep for example. When I check back after some hours the calculation is done (checking the files) but it does not continue to the next design point calculation. It is still solving the same design point. If I sit and play or stay active at the pc nothing goes wrong. If I update every design point manually, evrything perfect.I already tried to turn off sleep mode at power management in control panel and also put turning off disc option after more than 8 hours.I also discovered that this issue has something to do with the pc.At the university I have access to an unrestricted license of Ansys. I tried this at 2 pcs and the problem happened just at one of them. Unfortunately someone else has to work with this pc and I can't use the good one.At home I have the same issue but my pc is faster even with 4 cores.That is why it is very important to fix this problem for me. If someone has any idea I would be happy to read it. Thank you very much.ÂRegards,Jorge -
May 22, 2024 at 12:27 pm
- The topic ‘Problem updating design points of a parametric analysis in Fluent’ is closed to new replies.
