June 5, 2019 at 10:11 pm
JoaoBomfim3
SubscriberHÃ guys,
I have a problem when I use routines in FORTRAN in parallel mode. In serial mode there are no problems, but in parallel the error with code 30 appears. I put a copy of the cfx5mkext.ccl file with the correct architecture and the solver-mpi.lib line in the working directory and there is still the problem. Has anyone had this and solved it? I'm probably making a mistake in handling the cfx5mkext.ccl file. Thank you very much.
Viewing 0 reply threads
- The topic ‘Problem to run CFX solver with user fortran in parallel mode’ is closed to new replies.
Ansys Innovation Space
1208
1092
1068
952
