October 26, 2018 at 8:12 am
Yohann Biran
Hi,Â
A customer of spaceclaim as a problem with Spaceclaim 19.2 to import step file (or file different than scdoc).
This customer usually double clic on the file in the deskop, normally this action open the file in spaceclaim.Â
In the 2019.2 version of the software, when they do the same action, they have the error message "no servers provided : ANSYSLI_SERVERS: Flexlm SERVERS:"
I try also and I have the same problem.Â
In the front version, this action was possible.
Can you resolv the problem ?Â
regards
Yohann
October 26, 2018 at 8:34 am
Naresh Patre
Ansys EmployeeHello NOVACAD
Please check out below discussion thread for possible solution to this problem.
October 26, 2018 at 3:08 pm
Yohann Biran
SubscriberoK I try to change the key register value and add "/USERUNNINGSPACECLAIM=true".
But when I try to double click on a step file, the problem was always the same !
October 29, 2018 at 5:02 am
Naresh Patre
Ansys EmployeeNOVACADÂ There are multiple entries in the registry key for spaceclaim. You need to edit the correct entry as listed in below link. Can you check this and try out again?
October 29, 2018 at 10:12 am
Yohann Biran
SubscriberHi,Â
Ok, effectively i was not in the good registry key ! Now, if spaceclaim is open in my computer, he opens the step file on the new tab. But if Spaceclaim was not open, the problem persist !Â
I don't know why but it's impossible to force windows to open always step or stl file with spaceclaim. If I do that it's just for one time, even if i tick always open step files with this application.
RegardsÂ
Yohann
October 30, 2018 at 5:15 am
Naresh Patre
Ansys EmployeeNOVACADÂ I will have to check with the team and will get back to you.
October 31, 2018 at 6:34 am
Naresh Patre
I came to know that this is the intended outcome of that modification.Â
A knowledge article addressing this problem has been published on forum at this link.
- The topic ‘Problem to import file’ is closed to new replies.
