December 16, 2024 at 10:21 pm
leroy.dok
SubscriberIm trying to run a prameter sweep, and im unable to add a result to the results table in the edit window of the parameter sweep utility. Â
looks like a gui bug since it doesnt show the drop down list of options like it did when ive added the parameters to the parameter table (screenshot attached)
did someone encaountered this?
December 17, 2024 at 9:53 pm
Amrita Pati
Ansys EmployeeHi Leroy,
Unlike FDTD, you would have to run the simulation first (be in the analysis mode) to be able to select the mode results in FDE. And then you can select the result from the sweep. So, I will recommend running the simulation and then going into the sweep and selecting the desired result.
AmritaÂ
December 25, 2024 at 8:28 pm
leroy.dok
SubscriberIt worked! thank you very much
5284
1885
1403
1262
