December 2, 2020 at 11:53 am
kenbettle
SubscriberI've been conducting some piping analysis and have been experimenting between the use of a solid body model or an idealised pipe model using a cross section and line body. I noticed that the idealised pipe model expands less than would be expected.
I've conducted a simplified experiment with 1m sections of both an idealised line body model and a a solid model. Both have the same material properties and are subjected to the same temperature increase. both are fixed at one end and allowed to expand freely at the other.
But the idealised line body model does not expand to the correct amount.
Can anyone help me understand why?
December 2, 2020 at 1:33 pmDecember 2, 2020 at 2:04 pmDecember 2, 2020 at 2:05 pmkenbettle
SubscriberI also find that if I try to, I can't apply a thermal condition to the idealised model it won't allow it.nDecember 2, 2020 at 2:06 pmkenbettle
SubscriberHi @kenbettle ,Can you please check the model? I applied same thermal condition load to both solid and pipe models and the result were same:https://us.v-cdn.net/6032193/uploads/9SFGHS04O0EP/image.pngRegards,Ashish Khemka/forum/discussion/comment/99038#Comment_99038
see abovenDecember 2, 2020 at 3:24 pmAshish Khemka
Forum ModeratornThe Thermal Condition option applies a uniform temperature throughout the body and the Pipe temperature option applies a linear temperature distribution along thickness.nAre you not able to apply thermal condition to the line body? Use body selection filter when selecting the line body.nnRegards,nAshish KhemkanDecember 2, 2020 at 4:22 pmkenbettle
SubscriberAha! thanks! i knew it had to be a simple misunderstanding somewhere.nViewing 6 reply threads- The topic ‘Problem – thermal expansion difference between an idealised pipe model and a solid body pipe model’ is closed to new replies.
3150
1013
945
858
797
Ansys Assistant
Welcome to Ansys Assistant!
RETRY
