April 13, 2020 at 3:59 pm
TWard48
SubscriberHello, I am Tom, an engineering student learning ANSYS. For my assignment, I need to build an analysis with the following project schematic diagram
I was able to insert all three modules and share the engineering data and geometry between them by dragging and dropping, however, when I try to share models using the same drag and drop method, my cursor becomes a red cancel symbol and I am unable to make the shared connection. The same thing happens when I try to use the solution to one module in the setup for the following module. What am I doing wrong and how do I fix it?
April 14, 2020 at 12:29 am
TWard48
SubscriberOK, I think I figured it out, at least sort of. Take a new workbench project, insert the final analysis first, right click on setup, select transfer data from new, and select the desired previous analysis type. Data, Geometry and model will all be linked, as well as the solution from the previous analysis going into the setup of the following analysis. What I still don't understand, is why I can't do a static analysis, then insert a modal analysis and take the model and solution from the previous static analysis and insert it into the new modal analysis, as would seem more intuitive to me, doing it in sequential order, as opposed to the reverse sequential order ANSYS seems to mandate. Unless I am still missing something?
April 14, 2020 at 1:13 am
Aniket
Forum ModeratorTWard48, Insert Static system first
then drag Modal analysis system and drop it on the Solution cell of the existing static system (note first 3 cells of the static system will also be shared automatically)
then drag the Harmonic system and drop it on Solution cell of the Modal system.
Check the help page here:
If you can not open the page, check my signature for the process. Once you have opened you can click on the images to play interactive video.
-Aniket
How to show full resolution image
How to use Google to search within Ansys Student Community
July 27, 2023 at 11:22 am
- The topic ‘Problem sharing models in Project Schematic’ is closed to new replies.
4678
1565
1386
1241
.jpg?width=690&upscale=false)
