December 5, 2018 at 10:49 am
Mueller
Subscriber I am trying to repeat an example analyses of a piezoelectric circuit in Workbench (https://www.sharcnet.ca/Software/Ansys/17.0/en-us/help/ans_cou/Hlp_G_COU_N4_6.html).
I have defined piezo element properties of the same piezoelectric cube and top bottom electrodes. If I apply voltage, a simulation shows correct values. However, in the next step of adding CIRCU94 element by command lines I get an error:
Element 1729 does not have all of its required nodes defined. The E command is aborted.                                                   Â
The E command cannot store element 1729, possibly because one or more nodes is not defined.
Another issue is a command " *get,Cs,node,n_top,rf,chrg ", is it possible to read a charge value in Workbench without command line?
Thanks in advance.
Best
- The topic ‘Problem of connecting CIRCU94 element to the defined nodes by using E command’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3862
1414
1220
1118
1015
