3D Design
3D Design
Problem in generation of 2d model
    • rrathishubham
      Hello everyone I'm new to ANSYS so please dont mind if this is a really silly one. I'm trying to generate a model of cooling tower using axisymmetric but the problem is that i dont know how to place it at a position to get a proper radius and revolve it around y axis.
      I have attached a screenshot of cooling tower in 3d but i want the same in 2d. Please help.
      It's good to do an axisymmetric model when you can.
      For structural problems, the axis-of-rotation is the Global Y axis. Keep the geometry on the +X side of the Y axis.
      For fluids problems, the axis-of-rotation is the Global X axis. Keep the geometry on the +Y side of the X axis.
      ANSYS provides two Geometry editors, the newer one is SpaceClaim. There are several tutorials on SpaceClaim in the Tutorials section of this site.  You should become a little skilled at SpaceClaim and learn how to sketch and make a surface.
      Please describe what you want to simulate in some detail.
      Peter
    • rrathishubham
      I want to simulate in structure. I have tried a lot of times to create a 2d model but I always get an error saying " No valid bodeis found for 2D analysis".
      You didn't say if you are using SpaceClaim or DesignModeler.
      After you sketch a closed loop on the XY plane, you need to either:
      1. In SpaceClaim: Click the Pull tool or click the 3D mode button or
      2. In DesignModeler: Concept > Surfaces from Sketchs > Generate
      In either case, you will end up with a surface. This is what you need before you try to transfer geometry into Mechanical.
      Peter
    • rrathishubham
      Thankyou sir for your reply. But how do I specify the distance from y axis?
      It depends on whether you are using SpaceClaim or DesignModeler.
    • rrathishubham
      I will be using design modeler
      In DesignModeler, you click on the Dimension tab, select Horizontal dimension and click on the line and the dotted line of the Y axis.
    • rrathishubham
      Thankyou sir.
      Also sir, I want to create columns at the base of cooling tower at equal intervals. So how do I do that? I want columns at 20 degrees interval.
    • rrathishubham
      Sir, I have prepared the model in Revit and exported it to autocad in dwg format further i exported it to ANSYS in .iges file. And when I try to open mechanical, it says no valid bodies found.
      When you add columns at 20 degree intervals, that's not axisymmetric geometry, now it is a 3D model.
      A 3D model can be built from a surface of revolution, plus surfaces to represent the columns.
      I expect the iges file only had curves and no surfaces. Create surfaces and try to open that in Mechanical.
    • rrathishubham
      Sir, it would be very difficult for me to make the model in ANSYS because that thickness of cooling tower varies at every 2.5m and it has a height of 175m. Also it has varying radius at every 2.5m interval.
      Do you have a drawing that calls out the thickness and radius as a function of height?
      Please also reply with the load you wanted to apply to the cooling tower, was it only gravity?
      I recommend you finish the 2D axisymmetric model before you add in the columns.
      Then you can start a New Discussion for the 3D model.
    • rrathishubham
      Yes, i have the drawing that calls out thickness and radius as function of height.
      Loads to be applied on cooling tower: gravity, wind, seismic
      Only gravity is an axisymmetric load.  Wind and seismic are not.
      I recommend you finish the 2D axisymmetric model with just gravity to build some skill with ANSYS.
      Please share the details of the thickness and radius as a function of height.  You can insert an image into your reply of either sections of the drawing or a table.  You can also attach files after you post your reply. Put whatever file you have into a zip file and attach the zip file.
    • rrathishubham
      Sir, I'm not able to attach the files, can i get your mail id or something where i can send you the files??
      Do you have a zip file?
      What is the file size?
      When you click on the Attach button, Browse to the zip file and click Upload.
      You will see the file upload. Please try again and describe in detail what happens if it does not attach.
    • rrathishubham
      Its a zip file and the file size is 5.36 MB. When I select files and try to upload them, it shows 100% uploaded and it redirects me to same page and the files are not uploaded over there.
      Create three columns of numbers in a spreadsheet. Copy the three columns out of the spreadsheet and paste into Notepad. Format a line as Preformatted on the pull down in the toolbar. Copy all the lines out of Notepad and paste into that Preformatted line as shown below, except you will have 71 rows.
      height(m)	radius(m) 	thickness(m)
      0 20 1
      2.5 19.5 1
      5 19 1
      7.5 18.5 0.95
      10 18 0.95
       Alternatively, if you File, Save As the spreadsheet as a Text file and if the file has a .txt file extension, that is another allowed file extension for attaching files to replies. I know you were able to attach a .jpg file at the beginning. You can try to attach a .txt file now.
    • rrathishubham
      Sir, details of geometry are attached in text format.
      After you Reply, look at the buttons on the page and an Attach button appears. You have used that above. That is correct.  The problem with the file you attached is that it is empty.
      If you copy text out of Notepad, you can paste it directly into the Reply window where you are typing. That is what I did. Try that.
    • rrathishubham
      Note: Cooling tower starts from a height of 9.17m from ground as columns has a height of 9.17m
      height from ground (m)	radius (m)	thickness (m)
      9.17 58.71998481 1.05
      10 58.45077875 1.044153913
      12.5 57.64576787 1.032
      15 56.84976984 1.031590909
      17.5 56.06308598 1.031162791
      20 55.28602742 1.030714286
      22.5 54.51891525 1.030243902
      25 53.7620806 1.02975
      27.5 53.01586474 1.029230769
      30 52.28061906 1.028684211
      32.5 51.55670517 1.028108108
      35 50.84449475 1.0275
      37.5 50.14436954 1.026857143
      40 49.45672111 1.026176471
      42.5 48.78195074 1.025454545
      45 48.12046904 1.0246875
      47.5 47.4726957 1.023870968
      50 46.83905899 1.023
      52.5 46.21999524 1.022068966
      55 45.61594831 1.021071429
      57.5 45.02736878 1.02
      60 44.45471322 1.018846154
      62.5 43.89844326 1.0176
      65 43.35902455 1.01625
      67.5 42.83692562 1.014782609
      70 42.33261666 1.013181818
      72.5 41.84656813 1.011428571
      75 41.37924925 1.0095
      77.5 40.93112648 1.007368421
      80 40.50266173 1.005
      82.5 40.09431064 1.002352941
      85 39.70652064 0.999375
      87.5 39.33972898 0.996
      90 38.99436075 0.992142857
      92.5 38.67082672 0.987692308
      95 38.3695213 0.9825
      97.5 38.09082036 0.976363636
      100 37.83507916 0.969
      102.5 37.60263028 0.96
      105 37.3937816 0.94875
      107.5 37.20881436 0.934285714
      110 37.04798141 0.915
      112.5 36.9115055 0.888
      115 36.79957782 0.8475
      117.5 36.71235664 0.78
      120 36.64996625 0.645
      122.5 36.61249606 0.24
      125 36.6 0.24
      127.5 36.61220718 0.237938144
      130 36.64589883 0.237826087
      132.5 36.6949721 0.237701149
      135 36.75396376 0.237560976
      137.5 36.81920808 0.237402597
      140 36.88846925 0.237222222
      142.5 36.96039863 0.237014925
      145 37.03416464 0.236774194
      147.5 37.10923758 0.236491228
      150 37.18526839 0.236153846
      152.5 37.26201957 0.235744681
      155 37.33932479 0.235238095
      157.5 37.41706451 0.234594595
      160 37.49515085 0.23375
      162.5 37.57351785 0.232592593
      165 37.65211516 0.230909091
      167.5 37.73090367 0.228235294
      170 37.80985258 0.223333333
      172.5 37.88893734 0.211428571
      175 37.96813811 0.2
      176 37.99984718 0.2
    • rrathishubham
      height
      from ground (m)
      radius (m)
      thickness (m)
      9.17
      58.71998481
      1.05
      10
      58.45077875
      1.044153913
      12.5
      57.64576787
      1.032
      15
      56.84976984
      1.031590909
      17.5
      56.06308598
      1.031162791
      20
      55.28602742
      1.030714286
      22.5
      54.51891525
      1.030243902
      25
      53.7620806
      1.02975
      27.5
      53.01586474
      1.029230769
      30
      52.28061906
      1.028684211
      32.5
      51.55670517
      1.028108108
      35
      50.84449475
      1.0275
      37.5
      50.14436954
      1.026857143
      40
      49.45672111
      1.026176471
      42.5
      48.78195074
      1.025454545
      45
      48.12046904
      1.0246875
      47.5
      47.4726957
      1.023870968
      50
      46.83905899
      1.023
      52.5
      46.21999524
      1.022068966
      55
      45.61594831
      1.021071429
      57.5
      45.02736878
      1.02
      60
      44.45471322
      1.018846154
      62.5
      43.89844326
      1.0176
      65
      43.35902455
      1.01625
      67.5
      42.83692562
      1.014782609
      70
      42.33261666
      1.013181818
      72.5
      41.84656813
      1.011428571
      75
      41.37924925
      1.0095
      77.5
      40.93112648
      1.007368421
      80
      40.50266173
      1.005
      82.5
      40.09431064
      1.002352941
      85
      39.70652064
      0.999375
      87.5
      39.33972898
      0.996
      90
      38.99436075
      0.992142857
      92.5
      38.67082672
      0.987692308
      95
      38.3695213
      0.9825
      97.5
      38.09082036
      0.976363636
      100
      37.83507916
      0.969
      102.5
      37.60263028
      0.96
      105
      37.3937816
      0.94875
      107.5
      37.20881436
      0.934285714
      110
      37.04798141
      0.915
      112.5
      36.9115055
      0.888
      115
      36.79957782
      0.8475
      117.5
      36.71235664
      0.78
      120
      36.64996625
      0.645
      122.5
      36.61249606
      0.24
      125
      36.6
      0.24
      127.5
      36.61220718
      0.237938144
      130
      36.64589883
      0.237826087
      132.5
      36.6949721
      0.237701149
      135
      36.75396376
      0.237560976
      137.5
      36.81920808
      0.237402597
      140
      36.88846925
      0.237222222
      142.5
      36.96039863
      0.237014925
      145
      37.03416464
      0.236774194
      147.5
      37.10923758
      0.236491228
      150
      37.18526839
      0.236153846
      152.5
      37.26201957
      0.235744681
      155
      37.33932479
      0.235238095
      157.5
      37.41706451
      0.234594595
      160
      37.49515085
      0.23375
      162.5
      37.57351785
      0.232592593
      165
      37.65211516
      0.230909091
      167.5
      37.73090367
      0.228235294
      170
      37.80985258
      0.223333333
      172.5
      37.88893734
      0.211428571
      175
      37.96813811
      0.2
      176
      37.99984718
      0.2
      What version of ANSYS are you using:  18.2  19.2  other?
    • rrathishubham
      I'm using version 18.1
      Here is the plan. Take the spreadsheet and make two tabs, one for the inner surface, one for the outer surface. On the tab for the inner surface, delete the Thickness column. Cut the Radius column and paste it in front of the Height column. Now the first column is the X coordinate, the second column is the Y coordinate. Fill the third column with 0.0 for the Z coordinate.
      On the second tab, in the fourth column, add the radius to the thickness to make the Y coordinate of the outer surface. Cut that column and Paste Special (Values) in front of column A to be the X coordinate. The height is the Y coordinate and insert a column of 0.0 for the Z coordinate. Delete the other rows.
      Next you have to format those two tabs into the 3D Curve data format that DesignModeler requires.
      Once you have a text file with the data in the correct format, you start a new Workbench file. RMB on the Geometry cell and get the Properties.  You must set the Analysis Type to 2D before you open DesignModeler.
      In DesignModeler, Concept, 3D Curve. Definition > From Coordinates File. Then pick the inner surface file.  Repeat for the outer surface file.
      Finally, make a sketch that uses those two 3D curves and two lines to close off the cross-sectional surface that is the geometry that can be meshed to perform an axisymmetric model.
      Alternatively, you could put the inner and outer coordinates in one file and define a closed 3D line and you wouldn't have to sketch the two lines.
    • rrathishubham
      Thankyou so much for your reply. I'll revert back once i create the geometry. Once again thankyou sir, thanks a lot.
    • rrathishubham
      Sir, I was able to import the file and it created the curve as I wanted but could you please tell me that how do I create closed geometry? I even read the link you provided but I didn't understand that what should be the format for closed geometry and in the last row where shall I put 1 and 0 to close geometry.
      Forget about the closed curve.
      You can have four groups in a single text file.
      Group 1 can be the inner curve from the bottom to the top.
      Group 2 can be from the inner top to the outer top (two points).
      Group 3 can be the outer curve from top to bottom (reverse sort the height).
      Group 4 can be from the outer bottom to the inner bottom (two points).
      I think you will be able to select these four curves to make a surface.
    • rrathishubham
      Sir, I made the geometry using 4 groups and later using "Surface from Edges", I created surface. Is it correct? And once I take the geometry into mechanical tab, I cant see any option to revolve the geometry.
    • rrathishubham
      Also, can i put reinforcement in 2D model? Or do I need to model it in 3D? If I can put the reinforcement in 2D model, then how can I put?
    • rrathishubham
      Sir, I have revolved the geometry in mechanical tab. Also I have meshed it. Could just tell me about the reinforcement?
      A 2D axisymmetric model is used to calculate and visualize the stress and strain on a 2D radial slice of a 3D rotationally symmetric object. The surface you created from the four curves is that radial slice. The surface is what you mesh. You also have to support and load the structure. I suggest a fixed support for the bottom edge and Standard Earth Gravity in the -Y direction. By default, all models begin with Structural Steel. If you want to use a different material, you have to create that in Engineering Data, and then you have to assign that to the surface in Mechanical. Then you can solve and look at results. There is a way to display the results from the surface by revolving the results around the axis to display the results in 3D.
      Reinforcement is done in 3D. It doesn't make sense in 2D except for a hoop that goes around the axis. You can't have any axial reinforcements that are only every 20 degrees because that is not axisymmetric.
      I recommend you get results from a 2D axisymmetric model of an unreinforced material before you venture into 3D models.
      Once you have 2D results, you can mark this discussion with Is Solution and open a New Discussion for questions on reinforcements in 3D models.
    • rrathishubham
      Okay sir... And yes, the slice from 4 curves is radial slice. I'll try to do it without reinforcement.
Viewing 33 reply threads
  • The topic ‘Problem in generation of 2d model’ is closed to new replies.
