January 9, 2024 at 11:35 am
Furkan Yuşa Kılınç
SubscriberHello, I would like to design a simple basic pulley and this is what I have done so far:
Also, I have created contacts and joints like these:
I am trying to simply simulate a rotation. I have given the frictional coefficient as 0.5 and the joint - rotational velocity is 0.1 rad/sec. But the result looks like this:
The rope has turned with the pulley and I dont understand why. There is earth gravity I have added so that shouldnt happen, right? The materials I have chosen for pulley and rope is structural steel and resin epoxy, respectively. Any help is appreciated.
January 10, 2024 at 10:37 am
Ashish Khemka
Forum ModeratorHi,
Can you share the snapshots of how each joint and contact is defined? I tlooks that all the parts are deforming under gravity. Please refer to the following link as well:
How to model pulley systems and bollards with ropes under friction (ansys.com)
Ashish Khemka
January 10, 2024 at 8:17 pm
January 11, 2024 at 3:03 pm
Ashish Khemka
Forum ModeratorHi,
You can try giving displacement to the rope and pulley should turn with rope moving.
Ashish Khemka
January 11, 2024 at 3:13 pm
Ashish Khemka
Forum ModeratorAlso, please refer to the following posts:
How to Model a Rope in Ansys for a Mechanical Analysis
Issues with Mesh on “Beam, Model Type: Cable” Element (ansys.com)
Ashish Khemka
- The topic ‘Problem in Design of Basic Pulley’ is closed to new replies.
6600
1311
