October 26, 2021 at 9:57 pm
fea11
SubscriberOctober 27, 2021 at 1:45 pmGovindan Nagappan
Ansys EmployeeAnsys staff cannot download files from forum. Someone else could take a look at the model and help you with this
See if Multizone method helps create a hex mesh
Sweep requires one source face to one target face. Source and target should have same topology. That is if source face has 4 edges, target should also have 4 edges. If you have additional splits, the body is not sweepable. Check in wireframe mode and display vertices to see if there are additional splits. Merge selected edges using virtual topology to remove the spilt. (You do not have to use automatic virtual topology)
October 28, 2021 at 2:18 pmpeteroznewman
Subscribergave you good advice. You say you used the repair tools in SpaceClaim, but I just clicked the Split Edges button and found a problem.
In Mechanical, there is a split edge as shown by the Close Vertices button.
Going back to SpaceClaim, I find a sliver face that should be deleted.
After you delete that face, the body is sweepable and will hex mesh.
Viewing 2 reply threads- The topic ‘Problem in creating hexahedral mesh’ is closed to new replies.
5914
1306
