February 22, 2024 at 10:13 am
giuseppe.iacolino
SubscriberGood morning everyone,Â
I am facing an error in Composite Failure Tool.
I have designed a tube made of plies in composite material. I have also used Material Designer to create a Carbon Twill ply with +- 45° fiber direction.Â
So, I run the analysis and i get results.Â
After adding a Composite Failure Tool I get this error:Â
 '' Error evaluating Composite Failure result: composite::composite_failure_operator:612<-composite::minmax_per_element_operator:669<-composite::multiple_failure_criteria_operator:668<-composite::max_over_multiple_failure_criteria_operator:672<-composite::max_strain_operator:670<-1920 exceptions occured in parallel region. First exception: Material Evaluator: Missing property. Material evaluation failed: Current material `Carbon Twill +-45` (VUUID: 62ce0c05-9d60-4070-8f5c-3df51916243b). Property set name: Strain Limits. Property name: eXt. ''
May you please tell me why and what I should do in order to get results?Â
Kind Regards,Â
GiuseppeÂ
February 26, 2024 at 1:50 pm
Ashish Khemka
Forum ModeratorHi,
Is there a missing property value as indicated in the error message?
Ashish Khemka
February 26, 2024 at 2:02 pm
giuseppe.iacolino
SubscriberGood Evening Ashish,
thank you for the response.
I solved the problem. Having created the material using the Material Designer, as you suggested, I was missing some values in the material properties. By adding them, I resolved the issue.
Kind Regards,Â
GiuseppeÂ
- The topic ‘Problem in Composite Failure Tool’ is closed to new replies.
- APDL, memory, solid
- Meaning of the error
3977
1461
1272
1124
