TAGGED: ansys-designmodeler, constraints, designmodeler, lines, sketching
March 13, 2024 at 9:23 am
Atli Tobiasson
SubscriberHi,
In DesignModeler, I'm unable to change any constraints of lines after I draw them. In this case, I've imported a .step model, created a new plane on it, and started drawing lines. No matter where I draw them, I cannot add any dimensions because then it becomes overconstrained. I also don't know how to remove any of the unwanted constraints.
Unfortunately, I cannot include any pictures.
Best regards,
Atli
March 14, 2024 at 5:56 am
Keyur Kanade
Ansys EmployeeIf it is overconstrained then you will have to delete some constraints. Select them and delete them.Â
You can also check SpaceClaim.Â
Please go through help manual for more detailsÂ
Keyur
Fluids Engineering Courses | Ansys Innovation Courses
- The topic ‘Problem editing constraints in DesignModeler when drawing lines on .step model’ is closed to new replies.
- Add-in Error Excel
- Fileformats
- Spaceclaim problem
- Using SpaceClaim scripts vs recorded blocks for parametric optimization workflow
- Different Body Naming and Extra Surfaces after Importing Solid Edge Part
- racing royals
- New Computer
- Inconsistent Script
4612
1515
1386
1209
