October 15, 2024 at 8:18 am
23mce109
SubscriberGreeting,
I am currently working on a project where I have to analyse the cantilever bridge under lateral wind load.Â
I am getting this error during the meshing"Â
error: Breakout detected
Error: Front could not be closed at e1411 (48.080002 1.824990 1.000000)"
This is just a small part this is repeating multiple times maybe 600-700 times. Can anyone please improve the geometry/model I will be attaching the spaceclaim model here. and also explain why I am getting this error.
https://drive.google.com/file/d/1u5py94_nWh1Wb0R4Efx_T-f6D4mVspxM/view?usp=sharing
October 15, 2024 at 9:07 am
Forum ModeratorStaff aren't permitted to open or download files/attachments.Â
Check the cell size relative to the geometry and also that it's a sealed volume if you're using Watertight Workflow.Â
October 16, 2024 at 4:28 am
23mce109
SubscriberSir, can you please explain how I can do this? I have recently started working on this software.
October 16, 2024 at 7:53 am
Forum ModeratorHave you done the tutorials?Â
October 16, 2024 at 8:11 am
23mce109
SubscriberNo sir, where can I find them?
October 16, 2024 at 8:20 am
Forum ModeratorClick on Help in the solver or https://ansyshelp.ansys.com/public/account/secured?returnurl=/Views/Secured/main_page.html?hl=f and look in Fluent/Fluent Meshing section(s).Â
October 16, 2024 at 8:33 am
23mce109
SubscriberThankyou sir.
October 16, 2024 at 8:53 am
Forum ModeratorNot forgetting the "Learning" section here, it'll be in Fluids.Â
October 16, 2024 at 9:40 am
23mce109
Subscribersir is it possible to analyze bridge in the fluentÂ
October 16, 2024 at 10:55 am
Forum ModeratorWind, or water, flow around a bridge yes. Whether it's strong enough, sort of using Intrinsic FSI, but you may find Mechanical a better option for that.Â
October 17, 2024 at 5:24 am
23mce109
Subscribercan i do lateral load wind analysis in mechanical? How?
October 17, 2024 at 5:43 am
October 17, 2024 at 6:46 am
October 17, 2024 at 11:02 am
Forum ModeratorThat looks like the geometry needs checking properly. It's likely you have gaps/short edges and meshing is trying to resolve these.
Wind is just a force, so I assume you can add a load in Mechanical? I cover Fluent and whilst I can get pictures out of Mechanical their usefulness is debatable.Â
October 17, 2024 at 4:57 pm
23mce109
SubscriberSir, I am currently using Ansys, which works with a server license. I have to connect my laptop to the Wi-Fi of my institute to access it. Is there a way to use Ansys with any Wi-Fi or at any location? I would also like to work on the software at home but due to this problem, I am unable to do so.
October 18, 2024 at 8:42 am
Forum ModeratorYou just need to be connected to the campus system to see the licence, so check with local IT re a VPN link. But... also check the licence terms as remote use has restrictions.Â
The Student licence is for home learning, but comes with model size (mesh count) limitations.Â
October 18, 2024 at 10:56 am
23mce109
SubscriberI don't think it is a student license but a research-purpose license. I have to connect to the college wifi to access the license server after which I can run the ansys.
October 18, 2024 at 11:03 am
Forum ModeratorInwhich case you'll need to talk to your IT about VPN. You don't strictly need to be on the college Wifi but do need to be attached to the licence server which is on the campus network.Â
4818
1587
1386
1242
