September 27, 2023 at 7:08 am
Yun Seung Min
Subscriberi was trying to solve example of SPR which is in LS-Dyna example site.
https://www.dynaexamples.com/introduction/process_simulation/self-piercing-riveting
my status doesnt go further but in LS-run status is still running (cpu usage is amlost none at this moment)
message is end just like thisÂ
'Cutting plane= Â Â Â 3053 Â Â Â 3056 Â 0.80254E-01'
 i cant solve whole simulation because of this problem
how can i solve this example????
September 29, 2023 at 2:48 pm
Ram Gopisetti
Ansys EmployeeHi Yun,Â
try using SMP DP and use the solver version 13 and above, (usually the lower solver version should work with no issues as it was made Requires LS-DYNA SMP R7.1.2 (or higher) with single precision)
when we tested it, we found no issuesÂ
cheers, RamÂ
September 29, 2023 at 5:42 pm
Yun Seung Min
SubscriberThanks for feedback, Ram.
I tried using SMP DP version R13 and Revision: R13.1.1-17-ga451ec960f. (I check this at message file's second box)
Still same problem is happen.
as you see fig, message is end and status is still running. Is this problem is happen by memory? or really solver version of ls-dyna?
and this problem is also happen when i change failure option from *part_ADPTIVE_FAILURE to Mat 24's plastic strain failure.Â
If you dont mind, can you show me the ficture of end solution.
regards
- The topic ‘problem about *part_ADPTIVE_FAILURE’ is closed to new replies.
5674
1890
1419
1304
