September 27, 2017 at 11:19 am
admin
Ansys EmployeeIn Fluent, "!" issued at the command line runs OS commands. Current and date can be printed to files using the OS time and date commands: !time /T>file.txt !date /T>file.txt without the redirect to file, the commands print to the console On Windows, the DOS command "copy" can be invoked to copy the files time.txt and date.txt into a single file timestamp.txt > !copy time.txt + date.txt timestamp.txt time.txt date.txt 1 file(s) copied.
admin
Ansys EmployeeHow can I print the current time and date to IO or to a file in Fluent?
- The topic ‘Print the current time and date to IO or to a file in Fluent’ is closed to new replies.
