May 21, 2024 at 5:50 pm
Hubert Klatt
SubscriberHello!
I am a student and I am starting to work with Ansys for research purposes.
I need to design a girder prestressed with cables. In the Static Structural module, I set the cable cross-sections to "Link/Truss", but when I click "Solve" I get an error. Can anyone help me solve this problem or help me get rid of this problem? -
May 21, 2024 at 10:49 pm
Ankush Choudhary
Ansys EmployeeThe error shows your model is not fully constrained. You can use modal analysis to check which part is not fully constrained.
May 22, 2024 at 12:32 pm
Hubert Klatt
SubscriberHow can I check? -
May 22, 2024 at 1:19 pm
ErKo
Ansys EmployeeHi
See these discussions (your beams are probably not sharing common nodes so they are not connected).
/forum/forums/topic/solver-pivot-warning-in-beam-element-model/
All the best
Erik
May 22, 2024 at 3:45 pm
Hubert Klatt
SubscriberIs it possible to prestress the structure with the Link/Truss option?
Viewing 4 reply threads
- The topic ‘Prestressing the structure in the Static Structural module’ is closed to new replies.
