December 28, 2024 at 4:19 pm
josef.xerri.21
SubscriberHi,
I'm modelling a composite pressure vessel using APDL commands. This vessel is made up of 11 layers. The 1st layer is 1mm thick and the rest are 0.6mm thick. The length of the vessel is 100mm.
I fixed both ends of the vessel, however I can't seem to select the inner curved surface area to apply an internal pressure (last paragraph of the code). I've inserted the code that I wrote so far.
/Units,MPAÂ/Prep7ÂUIMP, 1, ex, ey, ez, 28.3e3, 5.35e3, 5.35e3UIMP, 1, gxy, gyz, gxz, 4.56e3, 3.29e3, 4.56e3UIMP, 1, prxy, pryz, prxz, 0.281, 0.305, 0.281ÂFC,1,s,xten,522 !F1t strengthFC,1,s,xcmp,-308 !F1c strengthFC,1,s,yten,13.3 !F2tstrengthFC,1,s,ycmp,-74.4 !F2cstrengthFC,1,s,zten,13.3 !F3t=F3c (large value, do not compute)FC,1,s,zcmp,-74.4 !F2cstrengthFC,1,s,xy,53.1 !F6 strengthFC,1,s,yz,1e4 !F4 strength (large value do not compute)ÂUIMP, 2, ex, ey, ez, 6.01e3, 6.01e3, 6.01e3UIMP, 2, gxy, gyz, gxz, 2.27e3, 2.27e3, 2.27e3UIMP, 2, prxy, pryz, prxz, 0.31, 0.31, 0.31ÂFC,2,s,xten,56.9 !F1t strengthFC,2,s,xcmp,-101.4 !F1c strengthFC,2,s,yten,56.9 !F2tstrengthFC,2,s,ycmp,-101.4 !F2cstrengthFC,2,s,zten,56.9 !F3t=F3c (large value, do not compute)FC,2,s,zcmp,-101.4 !F2cstrengthFC,2,s,xy,70.1 !F6 strengthÂ!*ask, n, Number of Layers (1-10), 5ÂET, 1, solid185,,,1KEYOPT, 1, 3, 1ÂSECTYPE, 1, shell,, josSECDATA, 1, 2, 0, 5, chopSECDATA, 0.6, 1, 0, 5, layerSECDATA, 0.6, 1, 0, 5, layerSECDATA, 0.6, 1, 0, 5, layerSECDATA, 0.6, 1, 0, 5, layerSECDATA, 0.6, 1, 0, 5, layerSECDATA, 0.6, 1, 0, 5, layerSECDATA, 0.6, 1, 0, 5, layerSECDATA, 0.6, 1, 0, 5, layerSECDATA, 0.6, 1, 0, 5, layerSECDATA, 0.6, 1, 0, 5, layerSECOFFSET, botÂCYLIND, 7, 14, 0, 100, 0, 360esize,2 !Element size 250mmmshape,1,3dvmesh,allÂfinishÂ/soluÂALLSEL, ALLASEL, S, LOC, Z, 0Â Â Â Â Â ! Select the circular area at Z = 0NSLA, SÂ Â Â Â Â Â Â Â Â Â ! Select nodes on the selected areaD, ALL, ALL, 0Â Â Â Â Â Â Â ! Fix all degrees of freedom (UX, UY, UZ)ALLSEL, ALLÂASEL, S, LOC, Z, 100Â Â Â Â ! Select the circular area at Z = 100 (top face)NSLA, SÂ Â Â Â Â Â Â Â Â Â ! Select nodes on the selected areaD, ALL, ALL, 0Â Â Â Â Â Â Â Â ! Fix all degrees of freedom (UX, UY, UZ)ALLSEL, ALLÂ! Select the inner curved surface areaASEL, S, LOC, X, 7Â Â !Select areas with radius R = 7ASEL, A, LOC, Y, 0Â Â !Select areas with radius R = 7ASEL, A, LOC, Z, 0, 100 !Refine the selection for Z-range from 0 to 100NSLA, SÂ Â Â Â Â Â Â Â Â Â ! Select nodes on the selected areaSFA, ALL, 1, PRES, 10ALLSEL, ALL -
January 2, 2025 at 3:37 pm
Deepak
Ansys EmployeeHi,
Select the cylindrical coordinate system before defining the pressure load.
CSYS,1,  !To active Cylindrical Coordinate system with global Cartesian Z as the axis of rotation.
Thanks,
Deepak
1890
1419
