June 11, 2020 at 2:24 pm
krany3
SubscriberI'm trying to include a pressure drop of 3% in the flow domain. How should I input that pressure drop?Â
Thanks
June 11, 2020 at 5:16 pm
Karthik Remella
AdministratorAre you looking for pressure inputs such that the inlet pressure is 3% larger than the outlet? If this is the case and if you are working on a incompressible flow, please use pressure inlet and outlet boundary conditions. The value at pressure inlet should be chosen such that the inlet pressure is larger than the outlet pressure by ~ 3%.
Thanks.
Karthik
June 11, 2020 at 8:17 pm
krany3
SubscriberThanks! But, if I define both the boundaries with pressure, how can I give velocity or flow rate at the inlet?
June 12, 2020 at 10:45 am
Forum ModeratorYou don't. Either pick a flow rate or pressure drop. The solver will calculate the other.Â
June 13, 2020 at 7:14 pm
krany3
SubscriberThanks! I'll try that
April 5, 2023 at 6:54 am
Shubham Dalvi
SubscriberÂ
- The topic ‘Pressure Drop in Fluent’ is closed to new replies.
3597
1263
1107
1068
953
