July 12, 2024 at 4:07 pm
Bryan Szloh
SubscriberHaving some problems with the pressure coefficient in Ansys Fluent for an airfoil I am modeling. The value of it seems to be too high. I am using the same airfoil surface as I did for the lift and drag coefficients that give values in the range that is expected. Any suggestions on what to look at to fix this?
July 15, 2024 at 10:50 am
Forum ModeratorHave a careful look in the Alphanumeric definitions in Fluent. I suspect that you've not adjusted the reference pressure, density, or area or similar. The Fluent result is likely correct for your settings (assuming convergence & mesh are good) but coefficients rely on constants that are often badly defined.Â
July 18, 2024 at 4:26 pm
Bryan Szloh
SubscriberThanks for the advice. I changed the pressure values in the Reference Values and inlet settings of my domain and got results that make much more sense.
- The topic ‘Pressure Coefficient of Airfoil in Ansys Fluent’ is closed to new replies.
5824
