December 4, 2023 at 3:57 pm
Aras karimi
SubscriberHi to all,
I drew the airfoil pressure coefficient distribution diagram as shown below in Fluent:
Then I export it as a text file and opened it in Excel software. I drew it in Excel, as shown below, the lines are placed on top of each other, and the irregularity can be seen in it:
What is the problem and what should I do to have a correct and regular curve?
Thanks in advance
Regards
December 4, 2023 at 7:12 pm
Federico
Ansys EmployeeHello Aras,Â
the points are not ordered, so I would suggest plotting using only the markers and suppressing the lines.
December 5, 2023 at 10:02 am
Aras karimi
SubscriberTo present the results, the pressure coefficient distribution should be plotted by lines.-
December 5, 2023 at 1:15 pm
Federico
Ansys EmployeeWell then you will have to order the points. That is an Excel issue.
December 6, 2023 at 9:44 am
Aras karimi
SubscriberThis is not Excel's problem, but Fluent's problem, which does not export the points in order.
In the papers, the pressure coefficient distribution curve is displayed by a line. How did they do this?
December 6, 2023 at 9:54 am
Forum ModeratorHow did you create the surface you're plotting on? Fluent does export the points in order, and they must be in order or your first image would also be a mess.Â
- The topic ‘Pressure coefficient curve’ is closed to new replies.
6535
1311
