TAGGED: -granta-edupack, material, material-properties
November 15, 2024 at 8:32 ame.risalitiSubscriber
I wanted to use the cost estimator for the material Press Hardening Steel, 22MnB5, austenized & H2O quenched, coated. In the selection of the primary process the only similar possibility is Hot closed die forging. Subsequently the material undergoes hardening but there is no possibility of choosing other processes other than geometry transformation (Shape). Also, manually looking into surface treatment processes but nothing with tempering. How could I best characterize the cost of the material?
Viewing 0 reply threads
Ansys Innovation Space
- Chemkin requires HPC
- Battery Simulation – Cannot access User-defined scalar (UDS) diffusivity
- Calculate heating of an assembly for a given ambient temperature?
- Doubt clarification on seed generation using ANSYS ADPL
- S-N (Wohler Graph) for steel X153CrMoV12 / D2 / NC11LV / K110 or similar
- Material Designer: Meshing difficulties
- Analysis of Shape memory alloys
- chemkin
447
395
225
201
