TAGGED: bolt-modelling, bolt-pretension, bolt-pretensioning, gasket, material
October 21, 2021 at 4:56 pm
Abhilash_G
SubscriberHello, I am simulating a bolted joint having 2 flanges and a gasket in between. The flanges are have 4 bolts at the diagonal and I am using 'Bolt pretension' feature to simulate it. I am using 3 load step adjustment , load (30kN) and lock and I am seeing a sharp increase in the preload (goes around 60kN) in the solution after probing.
I have checked all the associated parameters like contacts, gasket LD curves, etyc and they seem to be well. So could you suggest any possible solution/ reason for such high preload gain ?
Thanks,
Abhilash
October 27, 2021 at 12:21 pmAkshay Maniyar
Can you share the images of your model setup, bolt pretension and the plot for preload, so that forum members can help you in much better way.
Thanks,
Amaniyar
October 27, 2021 at 7:39 pmJohn Doyle
Ansys EmployeeTry to eliminate or minimize all the collective penetrations in the contact pairs within the bolt pretension load path. For example, if you have bonded contacts between bolt head/nut and plates, switch to MPC formulation. If you have frictional contacts between plates, increase the stiffness factor to '10' and turn off stiffness updating. Confirm that the resulting penetrations are considerably smaller than the adjustment in bolt pretension needed to achieve convergence.
Viewing 2 reply threads- The topic ‘Preload gain during the solution for gasketed bolted joint’ is closed to new replies.
