October 10, 2023 at 5:35 pm
Weihan Lin
SubscriberHi all,
I've been using pre-stressed modulue to modal analysis. Under "Static structural" -> "Analysis setting" -> "step controls", I changed the "step end time" from 10 sec to 100 sec and the results of natural frequency changed dramaticlly.Â
Does anyone know why is that and what kind of phenomenon behind it? Which simulation results should I trust?
October 10, 2023 at 6:51 pm
Ankush Choudhary
Ansys EmployeeHi Weihan,
Could you please check whether the stress values are changing in static structural with the change in step end time?
October 10, 2023 at 6:54 pm
October 10, 2023 at 11:45 pm
October 10, 2023 at 11:50 pm
Ankush Choudhary
Yes, this is the reason you are getting different natural frequencies, as the static structural data is coming at different time in Modal analysis. If you want to have the prestress data at the end of static structural, then you can change the option to program controlled, as I have shown above.
October 10, 2023 at 11:52 pm
Weihan Lin
SubscriberGot it. It did work! Thank you for the great help!Â
October 10, 2023 at 11:54 pm
Ankush Choudhary
Ansys EmployeeI am glad to hear that the issue is resolved now.?
- The topic ‘Pre-stressed modal why changing end time causes natural frequency to change?’ is closed to new replies.
5059
1770
1387
1248
