June 15, 2023 at 1:42 pm
Sebastien ARRIVET
SubscriberHi,
I'm trying to run a modal analysis with pre-stress.
I wrote this under:
/SOL!PreStressANTYPE,0PSTRES, ONSOLVEFINISH/SOL!Modal AnalysisANTYPE,2MODOPT,LANB,5,0,0, ,OFFEQSLV,SPAR ÂMXPAND,ALL, , ,YES ÂLUMPM,0PSTRES,ONSOLVEsave,analyse_modale,db,,allÂÂWhen ran separatly, both step works fine: the static step is correctly computed, and the result match with analytical solution.ÂHowever when ran before the modal analysis the db doesn't store the static solution. I've tried to multiply "save" command, but it didn't work.ÂIdealy I would like a single .db with the first static step and the second modal step.ÂDo you have any idea as to why it doesn't work ?ÂThanks for your help,Seb -
June 16, 2023 at 2:35 pm
dlooman
Ansys EmployeeThe database can only store one set of results. It's more typical to store results on the rst file. It may be possible to have both the static and modal results on the same results file, but that's not typical or easy to do. Why not issue save,static,db after the static? The reswrite command can be used to append results to an existing rst file.
June 16, 2023 at 2:38 pm
Sebastien ARRIVET
SubscriberThanks for your answer ! I'm not used to ANSYS APDL, so I had no idea. I will try rewrite in order to keep both results.
June 16, 2023 at 2:45 pm
Ashish Khemka
Forum ModeratorHi Seb,
Please see if the following link helps: 3.6. Applying Prestress Effects in a Modal Analysis (ansys.com)
PowerPoint Presentation (ansys.com)
Ashish Khemka
- The topic ‘Pre-stress step not showing on the db file’ is closed to new replies.
5834
