March 13, 2019 at 12:57 pm
fx213
SubscriberHello,
I am trying to apply load on a model`s surface, as displacement, for a structural analysis on a rubber,
but the surface, when I select after clicking on Geometry, Displacement, as it is set from the Project tree menu, then the Face icon and click on the surface and Apply afterwards, in the details of displacement does not seem to be defined (Image attached).
I have tried this several times, I have refresh and update the project and does not appear the displacement to be defined. Could I ask you why do you think this happens?
Regards,Â
FX
March 14, 2019 at 9:58 am
peteroznewman
SubscriberThat's not normal and doesn't happen for me in 19.2. Try deleting the Displacement, defining the Analysis Settings first, with Step End Time and Initial, Minimum and Maximum Time Steps, and the recreate the Displacement.Â
- The topic ‘Pre-processing’ is closed to new replies.
4673
1565
1386
1236
