June 9, 2022 at 1:17 am
papatel
SubscriberDear Team,
I hope you are doing well.
I am having a .dat.h5 file as an output even though I have set up "Legacy" in Fluent under preferences. I saved my case and a data file in .cas and .dat format. I have tried to follow all the suggestions in ANSYS 19, 20, 21, and 22. But, the problem remains the same while I am running my simulation in HPC. I cannot open .h5 file in CFD-post.
Could you please suggest? -
June 9, 2022 at 9:59 am
Amine Ben Hadj Ali
Ansys EmployeeOne can open CFF / H5 files in Ansys CFD-Post using the recent versions.-
June 10, 2022 at 1:10 am
papatel
SubscriberHi Amine,
Thanks for your reply. I tried to open it in even ANSYS 2022 R1. But, it didn't work.
June 9, 2022 at 1:13 pm
Forum ModeratorDid you set the preference in Fluent standalone and then run in Workbench (or vice versa)?-
June 10, 2022 at 1:13 am
papatel
SubscriberHi Robert,
Thanks for your reply. I have set up "Legacy" in fluent while I was in the Workbench. I saved fluent files (.cas and.dat). And then I run those files in the HPC system.
June 14, 2022 at 9:56 pm
nikhil.joshi
SubscriberHello Everyone,
I am doing a project and I am doing transient Thermal Analysis, after completing the simulation, I need the temperature history of geometry at each node (coordinate) at each time step in .txt, .xls or any other format so that I can use it for my ML algorithm. Please tell me how I can get it? -
June 15, 2022 at 11:59 am
Amine Ben Hadj Ali
Ansys Employee1/If you check the official documentation in Ansys CFD-Post can read CFF/H5 files. We still recommend exporting in CFD-Post Compatible Files for post-processing Fluent results in Ansys CFD-Post.
2/@nikhil: You can export ASCII Files under File/Export.
Viewing 4 reply threads
- The topic ‘Postprocessing file (.h5)’ is closed to new replies.
- affinity not set
1482
