Post Processing of Periodic Boundary Condition
    • bhuvaneshms2002
      I am working on a pipe flow problem involving liquid nitrogen flowing through a channel. I have applied periodic boundary conditions and successfully calculated the results. However, I am encountering difficulty in generating the contour on the specified plane. Even the if I create contour in other locations I am not geting anything on the plane created.
      Check the data range on the plot - ie are you clipping by value for some reason? Which solver are you using? Also why 2020R1?
