September 19, 2024 at 9:05 am
idenyu8701
SubscriberThank you for your response. I have carefully reviewed the provided content, but I am still encountering some difficulties with the post-processing of the FSI analysis.
I successfully imported the data for the fluid (case2) and the fluid-structure interaction (case1), but the structural data (case3 to case6) does not seem to have been imported successfully. I am not sure if this is the reason why I am unable to observe the mutual changes between the fluid and the structure in the post-processing results.
Can you please give me some more advice? -
September 19, 2024 at 12:35 pm
Federico
Ansys EmployeeHello,Â
You said structural results were not imported successfully? Did you get an error message or warning?
Which files did you import?
September 21, 2024 at 6:42 am
