July 17, 2023 at 6:34 am
Prashant Jha
SubscriberHello all
I am simulating rayleigh benard convection with two immiscible layers one on top of another. I have finished my simulations but when I go to post-processing and try to visualise the volume fraction through volume rendering, then I am getting no results. Also, when I plot the contours of volume fractions of different phases, then also I don't get the results. I have attached the screenshots below. Please someone help me out.
July 17, 2023 at 8:25 am
Forum ModeratorWhich solver did you use?Â
July 17, 2023 at 9:53 am
Prashant Jha
SubscriberI have used Fluent
July 17, 2023 at 10:07 am
Forum ModeratorOK. If you open an earlier time result in Fluent how does it look? How did you initialise the solution? How well resolved is the mesh?Â
July 17, 2023 at 10:14 am
Prashant Jha
SubscriberFor variables like pressure, velcoity and temperature, I get the results, just only when I want to see the volume fraction this error comes at any time step. I used standard initialisation from all zones. And the mesh is very fine of size 0.5 mm.
July 17, 2023 at 10:30 am
Forum ModeratorStandard? And no patching?Â
So, 50 cells across the domain and they're all square?Â
July 17, 2023 at 10:35 am
Prashant Jha
Subscriberyeah, i have done patching for the fluids with their respective regions. Number of cells are more, but the quality is very fine, that i checked using evaluate mesh quality optionÂ
July 17, 2023 at 10:43 am
Forum ModeratorThe quality metrics are just to tell you the cell quality, mesh quality also includes whether you have sufficient resolution of the flow/phase gradients.Â
How did the solution look at an earlier stage? How good was the convergence?
July 17, 2023 at 10:48 am
July 17, 2023 at 10:51 am
Forum ModeratorOK, so very poor convergence. And the mass monitors? Ie how much mass was lost per time step?
July 17, 2023 at 10:52 am
Prashant Jha
Subscribersorry but how to get that
July 17, 2023 at 11:11 am
Forum ModeratorVolume integral, but you'd need to have that set before the run. It's in Report Definitions.Â
July 17, 2023 at 11:14 am
Prashant Jha
Subscriberso now what to do, how can i visualise my phases?Â
July 17, 2023 at 11:52 am
Forum ModeratorI don't know if you have any phase to display - hence my suggesting opening an earlier save. I'd post process in Fluent for most tasks now, we very rarely use CFD Post for Fluent now.Â
- The topic ‘Post processing for multiphase vof’ is closed to new replies.
5939
1307
