May 8, 2018 at 11:27 pm
rrdbes
SubscriberANSYS Fluent: I have a heated surface having constant heat flux boundary condition exposed to the atmosphere and I wish to understand how surrounding environmental temperature changes after certain time.
I am doing a 2D steady state analysis. Where can i find the option to view the results at different time or instance during post processing? Thanks! -
May 9, 2018 at 12:41 am
peteroznewman
SubscriberSteady state means the solution when there is no change in any variable with time. The solution does not capture how the model changed from the initial conditions to the steady state values.
If you want to view the results at different times on the way to the steady state values, that is called a Transient analysis.
May 9, 2018 at 12:54 am
rrdbes
SubscriberDo you have any tutorials in setting up transient analysis with steady state values? Thank you!
May 9, 2018 at 11:11 am
peteroznewman
SubscriberRaef Kobeissi made this video.
https://www.youtube.com/watch?v=ApLGna4oMis
- The topic ‘Post Processing’ is closed to new replies.
Ansys Innovation Space
1273
1107
1068
953
