July 26, 2024 at 11:33 am
moritz.ruediger
SubscriberHi, I want to do some postprocessing of an already solved simulation.
Under solution I added an apdl code which also uses the command "set" and it works for the first run.
As soon as I execute the APDL code a second time I get the error "An error occurred while attempting to open the results file file.rst. ".The rst file is rather big 140 GB.Just the APDL code:
set,1
creates the error.
I use WB2023R2 Static Structural Simulation
July 29, 2024 at 10:49 am
Ashish Khemka
Forum ModeratorHi,
Please see if the following forum thread helps: Error occurred when the post processor attempted to load a specific result file (ansys.com)
Ashish Khemka
July 29, 2024 at 1:02 pm
moritz.ruediger
SubscriberHi,
unfortunately this doesn't help. The APDL works all the time after a fresh Workbench restart.
Just if I execute the post apdl command a second time it doesn't work.Â
July 29, 2024 at 2:01 pm
July 29, 2024 at 6:06 pm
moritz.ruediger
SubscriberThe post apdl command is executed within Workbench not in classic. In classic evwerthing works fine.
July 30, 2024 at 4:01 pm
dlooman
Ansys EmployeeI have found with commands objects that they sometimes work when they are executed immediately after the solution, but when you try to run them a 2nd time without rerunning the solution they don't. Sometimes it's necessary to issue a resume command at the top of the commands object (which would require a database to be saved in Analysis Settings> Data Management>). In the APDL gui when you issue the SET command without resuming a database the program asks if you want to recreate the database from the nodes and elements on the rst file. Perhaps that doesn't work in batch mode.
- The topic ‘Post APDL Command in Ansys Workbench fails’ is closed to new replies.
5884
1306
