November 28, 2024 at 1:04 pm
hallinenjesse
SubscriberdefResult = ExtAPI.DataModel.Project.Model.Analyses[0].Solution.Children[1]ds=ExtAPI.DataModel.InternalObject["ds"]labelID=ds.Graphics.AddLabel(defResult.ObjectId, 520, "DeformResult", 0.024, 0.004136, 0.0082857, 0x0000ff)# Arguments are: ObjectID, classID(520 for result), X_coor, Y_coor, Z_coor, color# This just creates an annotation probe with text "DeformResult" not the value of a result at that locationExtAPI.Graphics.Redraw()ÂThe python code above works pretty well for our use case, because we only need labels with some custom text, but now I got asked if we can edit those labels some more.So basically, is it possible to:- Detect which label was clicked and get its labelID?
- Remove the line that connects the label and the Point, so that label stays in the point location like normal annotations?
- Temporary hide some of the labels?
- Or basically edit anything else than what can be seen in the above code?
December 2, 2024 at 5:56 pm
mrife
Ansys EmployeeHi hallinenjesse
The Ansys Developers Portal Forum is open to the public and you can ask scripting questions there: https://discuss.ansys.com/
On that forum try searching for annotations then check on the 'Community Forum' box on the upper left. Then post your questions as needed.
Mike
