March 20, 2025 at 2:38 pm
matus.hornik
SubscriberI want to simulate an electric machine with translation movement in Z axis. It is a simulation in 3D so it takes a lot of time, so i want to simulate it with a symetry. I tried using independed/depended boundary but as my movement is in the middle it writes me: "Band can not touch matching boundary if the motion type is non-periodic translation motion or non-cylindrical rotational motion. " Is it possible to simulate translation movement with symetry in my case?
March 20, 2025 at 2:59 pm
GLUO
Ansys EmployeeHello,
Could you show a full model of this machine? Thanks.Â
GL
March 20, 2025 at 3:01 pm
GLUO
Ansys EmployeeAre you sure this is a translational movement instead of rotation? I just saw your previous post and it looks like the part in the middle is rotating around z.
March 21, 2025 at 8:46 am
matus.hornik
SubscriberI am pretty sure this is linear motion. It is Linear oscillatory motor. It is based on the theory in this research Novel Hybrid-Flux-Path Moving-Iron Linear Oscillatory Machine With Magnets on Stator | IEEE Journals & Magazine | IEEE Xplore. It does work with whole model, it does produce force in Z-axis as intended, it just takes hours to complete, as it is 3D double stator linear motion. With rotational it would not be problem to do the symetric simulation. But for the translation I dont know what to do with the band and bounderies touching.Â
March 28, 2025 at 4:13 pm
GLUO
Ansys EmployeeIf it is a translation alone z, your V vector should be at z direction. You can check periodic to make it accept your band settings and only simulate the first cycle.
GL
- Plotting Ex, Ey and Ez in vector forms individually
- How does Ansys Twin Builder implement different simulation steps for subcircuits
- Ansys-MATLAB Co-Simulation
- Maxwell circuit – PWM
- Y wiring method and the start and end points of winding.
- Compute near field simulation with current
- Ansys Resonance simulatioin error
- Double-sided LIM external circuit error
- Calculating E-field tangential to a 2D resonant structure on a sapphire chip
2738
959
824
599
591
