May 18, 2019 at 9:34 am
Meryl
SubscriberHey
I am designing a stacked microstrip antenna, when i excite the patch with a coaxial probe feed this is the error i get:
AMS_design (D
Asymmetric MS/)
 HFSSDesign1 (DrivenTerminal)
   [error] Port refinement, process hf3d error: Too few conductors were found on port 1. There should be one conductor for each terminal, with one additional reference conductor. Unintentional contact between conductors may cause this error.. (2:52:59 PM May 18, 2019)
   [error] Simulation completed with execution error on server: Local Machine. (2:52:59 PM May 18, 2019)
Please help me rectify the error.
Thank you
May 20, 2019 at 3:15 pm
Sorceress Gia
Ansys EmployeeCan you post a screenshot of how you're defining the port? Make sure that you are defining the port on a 2D sheet that is touching two separate conductors on two different edges...
May 28, 2019 at 4:39 am
Meryl
SubscriberThanku Sir, the error is now rectified.
October 5, 2020 at 9:02 pm
- The topic ‘Port Refinement error in coaxial probe fed stacked microstrip antenna’ is closed to new replies.
5069
1771
1387
1248
