Porous media
    • koltesomesh20
      Is their difference in velocity distribution in porous media and empty pipe. I am doing simulation using physical velocity in porous media. But i can't see the difference in velocity in porous media and without porous media section
      What resistance coefficients did you set? Please plot contours of velocity to illustrate the problem.
    • DrAmine
      Using superficial velocity formulation you will only see pressure drop.
    • koltesomesh20
      I am using physical velocity formulation in cell zone condition but there is no velocity change. i can see only pressure drop. i am using standard initialization. If I am wrong please correct me.
    • koltesomesh20
      viscous  resistance 4.09e+10 and inertia resistance 107306.7
    • DrAmine
      Can you plot path-lines colored by velocity magnitude through the porous zone.
    • koltesomesh20
      I had plot streamlines for velocity but their is no difference in colour and magnitude
      Please post the images, pressure drop and velocity. Also please add any solutions on here rather than keeping them to yourself!
    • koltesomesh20
      hi..I got the solution. Use physical velocity in fluid dialogue box. And also use only standard initialization if u use habride initialization u will not reach to actual solution
    • koltesomesh20
      When porous material in thermal equilibrium with fluid. Can we get temperature drop in fluid along the pressure drop????
      Have a look in the contours.
    • koltesomesh20
      is their someone working in refrigerant flow through porous media????
      I need some help please....
      Maybe add some images? Amine and I have suggested a few plots, sharing those would help us understand what you're doing.
Viewing 12 reply threads
  • The topic ‘Porous media’ is closed to new replies.
