December 19, 2024 at 7:03 am
January 6, 2025 at 1:27 pm
Prashanth
Ansys EmployeeHi,
the errors listed in your listing file happens sometimes in larger and longer polyflow calculations I think. The solver updates the res files every step. When there are some issues with the directory path access, or TMP storage getting full etc, these issues happens. You can try clearing your temporary files, setup a new larger TMP folder using a environment variable, make sure you have enough storage to address these errors.
January 9, 2025 at 5:57 am
729057384
SubscriberThank you. After following your instructions, the problem has been solved. It is true that the temp folder is not stored enough.
