October 5, 2023 at 12:55 pm
KarlDD
SubscriberDear all,
my task is to simulate the flow around an obstacle in a 3D domain described by a rectangular box.
boundary conditions: 1x inlet, 1x outlet, 2x symmetry, 2x periodic
surface of obstacle: no-slip wall
My question w.r.t. Fluent Meshing (Watertight Geometry):
I want to have a poly-hexcore mesh with polyhedral cells only in the vicinity of the obstacle and hexahedral cells anywhere else upto the domain boundaries.
However, with poly-hexcore volume mesh settings, I get polyhedral cells at the domain boundaries.Is there any way to get hexahedral cells upto the domain boundaries?
Thanks for your help!
October 5, 2023 at 1:19 pm
Forum ModeratorYou will, Fluent Meshing adds poly cells and then switches to hexcore away from the surfaces.Â
October 5, 2023 at 1:47 pm
KarlDD
SubscriberSo what can I do that Fluent Meshing creates a hexcore mesh directly at domain boundaries (not switching from poly cells to hexcore)?
I want to have poly cells only around the obstacle, but not at domain boundaries...
October 5, 2023 at 2:00 pm
Forum ModeratorYou can't, that's how the poly-hexcore mesher works. Is there a reason for not wanting poly cells at the outer regions?Â
October 6, 2023 at 8:59 am
KarlDD
SubscriberFor domain boundaries with periodic boundary condition and remarkable flow over these boundaries, I prefer to have a structured grid - in particular if the shape of the domain (in my case a rectangular box) allows to have hexcore cells upto the domain boundaries...
October 6, 2023 at 3:42 pm
Forum ModeratorYou can use Ansys Meshing and decompose the domain, but I generally just use a full poly mesh.Â
October 6, 2023 at 3:47 pm
KarlDD
SubscriberOk, thanks!
- The topic ‘Poly-hexcore volume mesh with hexahedral cells upto domain boundaries’ is closed to new replies.
6104
