March 28, 2019 at 2:29 am
samihawasli
SubscriberHello,
I am trying to understand what's the direction of propagation and polarization for a incident plane wave, defined using spherical coordinates and swept about an axis. There is an example Ansys provides, and in the documentation it shows how to define a plane wave. I do not fully understand what is meant by "the polarization is phi directed".Â
When defining a plane wave in Cartesian coordinates, the k and Eo vector are quite obvious. But in the example above, where are k and Eo pointed?
Thanks in advance,
Sami
May 3, 2019 at 6:44 pm
rtk
Ansys EmployeeThe Eo & k entity of Plane wave excitation in Cartesian coordinates denotes the resultant of E field & direction of wave propagation, respectively.Â
Whereas, in Spherical coordinates IWavePhi & IWaveTheta decides the incident angle or direction of propagation, and values of Eo vector (phi & theta) determines the E vector components, thereby defines the resultant E.
So 'the polarization is phi directed' means the E vector (resultant)Â has only Ephi component.
December 30, 2019 at 2:01 am
bamoghol
SubscriberHi roshnatk,
Please, do you know how set the floquet port excitation in order to get the polarization 45deg out of the principale axis x and y?
Thanks for your help.
- The topic ‘Polarization of incident plane wave in HFSS-IE’ is closed to new replies.
- Lumped Port Deembed
- HFSS libnvidia-ml.so too old or could not be found – Warning in slurm job output
- Hfss 3D pcb via capped and filled with epoxy
- Optimizing Via Impedance in Ansys HFSS 3D Layout Using Geometric Parameter Sweep
- AEDT Natural Convection with default correlation is failing solver initializatio
- STL Import Errors in HFSS After Cleaning in SpaceClaim
- Calc Error in Field Calculator after PyAEDT Analyze
- import file autocad 3d
- Co-simulation in Q3D, Icepak – meshing problem
4092
1487
1318
1156
